After many years, about thirty or so,! of spinning analogue tape, I am just now getting back to setting up a small home recording studio. I have been out of the loop with the home studio thing for over fifteen years now.
I'm hoping that with the expertise here on the forum, I may be able to eventually get my head around a lot of this "digital techy stuff," that's out there these days, especially this whole “digital mixer in software thing.”
Basic GEAR that I just purchased or previously owned, that I will use in setting up my home studio:
1) MOTU 828mk3
2) ZOOM HD16 Digital recorder
3) Behringer Euro 12 channel mixer
4) Behringer Active 8" Studio Monitors
5) Two patch bays, (1) Gaines Audio balanced, (1) ProCo 48 point unbalanced
The Gaines is strictly half normalled - while the ProCo can be normalled, half normalled, or open.
6) Enough Cables and Snakes to wrap around the universe - twice
7) A 2.8ghz dual core PC running WIN 7 Ultimate with 8GB Ram
My Goal is to TRACK, MONITOR, AND MIX using these two basic scenarios:
Scenario #1
The goal is to track, monitor, and mix a recording
mainly by myself. I'm a guitarist.
1) Multiple guitar parts into Cubase
2) MIDI keyboard into Cubase trigerring bass sounds etc.
3) Trigger VST instruments like EZ Drummer and Steinberg's Grand Piano from MIDI keyboard
Scenario #2
The goal is to track, monitor, and mixing down a small jazz ensemble
involving the following instrumentation: bass (electric or acoustic,)
a small set of jazz drums, a vocalist, and keys.
Basically, to track, monitor, and mix a group of five people.
1) Guitar parts direct into Cubase
2) Keyboards direct into Cubase
3) Mic on the upright bass
4) Mic for vocalist
5) Two overhead mics on the drum set
6) One mic on the snare drum
I would like to have some faders under my hand to control volumes. I tried using the MOTU 828mk3 as suggested in the manual, ie: “All in the Box,” by eliminating a hardware mixer, and almost took my head off . . . with a massive volume spike. Luckily, my 1031A Behringer monitors have some type of “protective circuit” built in.
* My biggest questions and confusions:
1) How do I setup or route, all the inputs and outputs in Cubase 5 as it relates to the MOTU inputs and outputs and my analogue or digital mixer?
2) Can I integrate my ZOOM HD16 as a mixer to control all the MOTU inputs, outputs? Do I need to set some type of clock thing going if I do connect them, even if I am just plugging in the MOTU mk3 outputs into that mixer to monitor the sounds? The ZOOM HD16 is mainly a hardware recorder, but I do know that it can be used as a Control Surface for Cubase 5. I have been able to get it to control Cubase's internal faders and such at one point, while just using the ZOOM and Cubase together.
3) Right now for ease of setup, to monitor the sounds from the MOTU, I have the MAIN OUTS of the MOTU mk3 coming into my Behringer 1202 small mixer on channels 11-12 which I use to control the overall volume of the MOTU and Cubase.
* I then have the Main Outs of the Behringer 1202 mixer going into my Behringer active monitors.
So I can hear everything. Then I just use the main fader on the Euro 1202 to control my overall volume. Very basic, but it works so far. Not much flexibility though, because it is just the Main Outs as one big group coming out of the MOTU.
4) That CueMix software seems pretty convoluted to an ole' analogue guy like myself? Do I need a PHD degree in metaphysics or quantum physics – or both ???
I seem to be praying to find a signal as I wade through that thing.
I like simplicity at this age. Someone with the “new know how,” out there, surely must have an idea with this specific gear.
5) I also read in the MOTU mk3 manual, that I can use ONLY Cubase to control CueMix by using Direct Monitoring, is that correct? And how would I access the MOTU FX and compression etc. from just using Cubase?
So basically, I am wondering what the best integration/use of my gear would be for my goals outlined above:
I'd like to keep it “simple.”
Use ALL three pieces of Basic Hardware?:
MOTUmk3, Behringer 1202 mixer, & ZOOM HD16 Recorder.
(With the patch bays or without ?)
Use the Behringer 1202 mixer to monitor outputs by running ALL the MOTU outputs into it, so that I have a hardware mixer with some faders under my fingers.
And then use the ZOOM HD16 ONLY as a Control Surface unit, to control Cubase after the initial recording is done?
Finally, thanks to any and all for your musical and technical input, suggestions, and/or expert advice!
