Lost Core Audio Output capability...
jpmason
Post by jpmason »
I have lost OUTPUT capability on my Focusrite Saffire Pro 40. System preferences sees it as an INPUT device but not OUTPUT.
I was working in DP as normal, went to check some settings in Saffire Mix Control and the Mac went to a white screen CRASH (first ever with this new fella). Since then attempting to load DP gives an error message :-
Unexpected error (MotuAudioSystem Mas CoreAudio error tahw, getBasicStreamInfo 1427 etc.)
I have tried reloading Focusrite software / checked cables / re-booted everything even did a repair permissions....but nothing has worked!
Is there anyway I can "reboot" core audio? Help anyone :shock:
iMac 27inch (2012), 3.4Ghz i7, 8 Gig RAM, 1Tb Fusion Drive, OS 10.8.2. DP8, Mach5 V2, Various Waves Plugs. Focusrite Saffire Pro 40, Adam A7X.
Re: Lost Core Audio Output capability...
You might have better luck getting answers over at Focusrite. You might also trash you Audio/MIDI (Apple's a/m that is) setup and start a new, fresh one. Kill the a/m plist first, then delete the current setup and start a new scan for devices if it (The Saffire) doesn't show up. I have the 24 Pro DSP model which I like a lot but with the Track 16 in the studio, I just can't go back and won't be much help in troubleshooting much further.
DavidAtFocusrite
Post by DavidAtFocusrite »
Hi jpmason,
This is rare but known issue on some Pro 40's, and we do have fix for it. Please contact our tech support team via the link below and we'll be glad to get you sorted out.
http://www.focusrite.com/answerbase/en/contact.php
Best regards,
David Tichauer // Focusrite Technical Support
jpmason
Post by jpmason »
Thanks MLC...I have logged a case with Focusrite.
I borrowed an old MOTU 828Mk2 from a friend (the display has gone) but I connected it up and the Mac picked it up straight away for both input and output. DP likewise!
I then tried the Saffire....same problem no Output!
I think my Saffire has a problem....it's only 6 months old, let's hope there is some sort of hard reset that can be done :cry:
jpmason
Post by jpmason »
Good news...thanks David, I have already sent Focurite Support a mail so hopefully we can resolve this issue quickly....feeling much more optimistic now....Thanks again :)
jpmason
Post by jpmason »
Focusrite support came up trumps, using a Dicetool and some great instructions was able to re-install the Saffire Firmware using the Mac terminal.....result :o
jpmason wrote:...using a Dicetool...
What's that?
