... I must enable each band for it to work. I mean - they all come up at zero so if you don't want to mess with one just leave it alone, right? But if I just grab one upon opening the plug to boost or cut what I want (of course) nothing will happen unless I go and enable that particular one.
Yes - we are spoiled but with thousands of mouse movements every day I hate to be using so many with absolutely no purpose except to enable something which should be enabled when I open it up.
Rant complete. And hoping someone will post back : "dummy - you don't have to do that, you can just......."
Mac Pro (early 2009 - originally 4,1 - flashed to 5,1) 2 x 3.42 GHz 6-Core Xeon X5690, 64 gigs PC3-10600 RAM, OS 10.13.3, DP9.52, UAD2 duo, UAD2 solo,
Superior drummer 2, Mach 5-3, Ivory, PCIe 424, BL modded 24i/o, MIDI express XT, unisyn, Melodyne 2, Izotope RX2, Addictive Drums, Pianoteq
zandurian wrote:... I must enable each band for it to work. I mean - they all come up at zero so if you don't want to mess with one just leave it alone, right? But if I just grab one upon opening the plug to boost or cut what I want (of course) nothing will happen unless I go and enable that particular one.
What Cuttime said: save a preset with all on, or even with a setting that you use a lot.
|l|OS X 10.12.6 |l| DP 10.0|l|2.4 GHz 12-Core MacPro Mid-2012|l|40GB RAM|l|Mach5.3|l|Waves 9.x|l|Altiverb|l|Ivory 2 New York Steinway |l|Wallander WIVI 2.30 Winds, Brass, Saxes|l|Garritan Aria|l|VSL 5.3.1 and VSL Pro 2.3.1 |l|Yamaha WX-5 MIDI Wind Controller|l|Roland FC-300|l|
You know, I know we get to pick nits every so often, but this doesn't seem that big a deal. And there may be a reason. I could be to preserve processor cycles. Some plugs were designed when Macs weren't as possible and it just might be that any "active" band, even if flat, would put a small load on the CPU and at one time it was worth coding a plug-in as to avoid that by having to activate a band first. That behavior, BTW, isn't that uncommon in EQ plugs from what I've seen.
cuttime wrote:Why not save "all on" as a preset? Two mouse clicks instead of seven.
Yep, or save a preset like that already inserted into a channel within the main templates and just option drag it to any channel. The point is there is no reason to have to do that. If I open a parametric eq it means I want to drag that crap around - and I mean right now!!!!
James Steele wrote: but this doesn't seem that big a deal. And there may be a reason. I could be to preserve processor cycles. Some plugs were designed when Macs weren't as possible and it just might be that any "active" band, even if flat, would put a small load on the CPU and at one time it was worth coding a plug-in as to avoid that by having to activate a band first. That behavior, BTW, isn't that uncommon in EQ plugs from what I've seen.
I'm opening up new instances of that plug 7 days a week so it adds up - and for any modern computer it's completely unnecessary. With age and borderline carpal tunnel every click of the mouse matters.
If there is any good reason to leave it as is then fine, but I don't think there are any.
In DP8 the window you use to select plugins is the same one you use to select presets. So once you've saved the eq plugin with all bands activated, it's the same number of clicks to open that as it is to open the plugin with all the presets deactivated.
Furthermore, you can save ALL the plugins for a given channel strip using the topmost slot. That saves each plugin's preset in that channel as well. For each channel that will be using those same plugins, you can then load the channel preset in that top slot, and all the plugins will appear, ready with their presets. That gives you an instant starting point that's going to be close to all the settings you want for each channel, if not exactly the same. Save it with a name that identifies what it is for you, because you will be able to load this into other projects as well.
Shoosh
I think the one in MachFive works that way so who knows, maybe just a matter of time. Then again, I thought I had heard that MOTU jobbed that software out to another company, so maybe not.
