I was an early DP user and left ship for a while around 2.7. At that time I used an EMU E6400 Ultra for just about everything. I would use MIDI only for most of the songwriting process, so I would use Chunks to separate out drums, verse, chorus etc. mess around with it in the Song window then eventually consolidate. I loved this workflow. It was a fluke bug in DP and my love for Logic at the time (I'm one of those weirdos that liked Logic pre-Apple buyout but not much after), that had me using Logic etc.
Years later most of my workflow is in plug ins, and using Chunks in the Song window etc. works best if you keep everything in V-Racks. Problem there is the V- Racks are mainly designed for improvising or playing an instrument live, track automation isn't possible, only MIDI automation if the plug in supports it.
So here's my proposal for MOTU on this, and I know I'm probably just yapping with no real chance of being taken seriously: collective or Linked Chunks. The idea would be that anything you add to a Chunk of this sort would be duplicated across all Linked Chunks. So if you change a track name, from say VSL-3 to Cello-3 it changes in all Chunks. All VI's are linked, so an instance of a plug in is actually not repeated in this type of Chunk, and you could still use DP's amazing track automation. Essentially the only difference in the various linked chunks in a project would be what's on the timeline MIDI and audio wise. This would allow users to use the Song window to try out various arrangements quickly.
It's possible now to use clippings and Chunks to a degree in this manner, but you use an open sequence to do this, which works pretty well, it's just not as elegant. I want my old workflow back!
Not that it will do anything, but what avenue would I take to offer up my unwanted advice?
