896hd output question
I have an 896 HD which I am using to go to the optical ins of my PT system. When I open Cuemix to assign the analog ins to ADAT outs, it only shows me ADAT outs 1 through 4. Not sure what is going on. Would appreciate any help. Thanks in advance for the help.
Re: 896hd output question
Sorry - forgot to add Mac OS 10.6.8, Protools 8HD, Cuemix 1.6 55333
- Dan Walsh
does cuemix even work with the 896HD? I don't think it does but I'm not sure.....
iMac 3.06 i3|OSX 10.6.8|8 gig ram||DP 7.24|Motu 896HD|2 Avalon VT 737's|Presonus ADL600|Slate VCC|Superior Drummer 2|EZ Drummer|1.1.6|Kontakt Player 4.1|Steven Slate Drums EX|SampleTank 2 XTAntares ATR-1|Presonus Central Station|Neumann TLM 103|Rode NT1|Audio Technica AT 4033 X2| Rode NT-5's|and lot's of other junk
It does (at least it recognizes the device and I can program the 896 with it) and the first time I used it it showed me 8 ADAT outs. Now only 4. Hence my bewilderment. Needless to say, losing four ins to PT is a limitation.
you may have to enable both adat out in Motu Audio Setup ?
Best
Klaus
Best
Klaus
Are you using 96KHz? It should only work with 4 channels through ADAT if so.
http://www.cueaudio.org
Macpro 3.1 Octocore-16Gb RAM-OSX10.8 - DP 7.24
Macbook pro Core2Duo-4Gb RAM-OSX10.6 - DP 7.24
Actually using 8.2, but it's the same answer. It came to me on the way home from the gig last night. Should have known. Thanks.
