I was trying to burn master of my project from DP7 and it was repetedly disrupted few seconds before completing. The error massage says something about that the burned disk would not be OK and indeed, it's not. The CD player loads the CD, correctly reads the number of tracks and the length of project, but in the last track, just about 10 seconds before the end of my "masterpeace"
The project looks like:
- 15 soundbites (44,1 kHz/16 bit) in two stereo tracks to make nice crossfades between tracks
- just simple corrections of volume using volume automation
- the master channel with just one plugin - for metering, to see if everything is under zero
- I gave markers to the desired beginnings of tracks which are named after the compositions to make them the CD text for particular tracks. So there are 15 markers - first on the zero to give name to the first track, etc...
There is nothing more I could say about it at this time. I select the project in its wholeness, from beginning to end, and "bounce", choose "burn to cd". And that's it.
Any ideas? Is it problem of DP7 or it could be problem of computer (white macbook) or the CD burner?
Thanks for your time and advices.
Pakub
