Enlarging the mixer
Enlarging the mixer
Hey guys, anyway to make the mixer larger ? When I am setting up discreet headphone mixes to 3 or 4 rooms in my studio , the sends are very small. Hard to see in the heat of battle. Thanks
2009 8 Core 5.1, 2012 6 Core MacPro,s , (32 gigs Ram) Mojave 14.6, Radeon 570, MacBookPros 2011, 2017 , 828MKIII Hybrid, 828X, MicroBook II, 8Pre, Nuendo 8ch A/D converter, PreSonus DigiMax LT ,DP11 , PT 2022.12, Cubase Elements 10.5, Peak 7, Logic 9 ,WaveLab 11, Reason 10, DSP-Quattro 5 ,many plugins , mics and synths. http://www.panaccimusic.com
Re: Enlarging the mixer
I guess you could change your display resolution.
If you run two displays, as many of us do, you can control the resolution on each independently of the other.
With decent 23" displays available below $150, this doesn't cost much to do.
You can toggle between a large and small mixer using …
shift +command+N
perhaps you're on the smaller graphic size of the mixer , hence , the smaller send buttons
HTH
schweats
shift +command+N
HTH
schweats
Schweats
MacPro 2.8/OS 10.10.1/6g ram/Powerbook G4/1g ram/10.4.11/828 mk3 hybrid/MTP AV usb/DP 7.23/Stylus RMX/Omnisphere/Trilian/Mach Five v2/RealGuitar/Korg Oasys/UAD2-Quad card & various plugs/Novation Zero SL mk2 controller/Akai MPK61
Looks like I will have to use the resolution. Never thought about that. The ProTools mixer has larger sends. I am used to that.
also don't forget about the zooming features built into osx
