I hope you can help me as well so first of all thanks for reading me.
I have a serious issue: I bought a second Ultralite in order to have more analog outputs but it doesn't work at all (and I don't know if I have to ask for a refund of the second MOTU if you don't find the solution).
When I don't use the USB hub requested on MOTU doc (not using FW because I have a Windows laptop without firewire), I always have 2 cuemix fx windows (#1 & #2, which is normal). When I use the USB hub, it bugs quite everytime on Windows 7.
But it is not the most important bug for me (because, but tell me if it is not something to do, I can forget the USB hub and plug each Ultralite on different USB ports of my laptop in order to see the 2 cuemix fx windows). The most important is when I launch Ableton 8 because (setup ok with 2 cuemix fx windows) Live gives 2 error messages. Then you see the Live project but without soundcard choosen. So I go on setup options, choose ASIO driver and then the MOTU card and Live closes itself without any info...
Do you see what I have to try?
Kind regards,
Francilien
