When doing paralell bus work, there can be phasing problems between the direct out of the audio tracks and the AUX send bussed signal with inserted plug-ins on the AUX master.
This seem to be a problem in most DAWs as the AUX is not inserted on the audio track itself and that makes it hard for the DAW to know how to compensate for the inserted plug-ins on the AUX master bus.
So I wish MOTU could find a way to fix this.
Maybe an indicator how many samples tracks are latency compensated for on every track? (As seen in PT) and/or a plug-in to insert these kind of values on the AUX track?
And add to that Time/latency compensation for send and returns on inserts OTB to outboard like FX and compressors looped back to DP.
