Missing an output on 2408MkIII using TDIF
CurtZHP
Post by CurtZHP »
My setup is as follows: 2408mk3 connected to Tascam DM-24 mixer via three TDIF cables. PCI-424 card.
I was mixing on the DM-24, using my DAW as playback to all 24 channels of the 2408. The problem is that whatever is assigned to TDIF Bank B Channel 8 does not pass audio.
I've tried a couple different DAW programs, so it's not a software routing issue. No matter what I send to it, the output LED for that channel does not light and I hear no audio. All other outputs work fine.
I was about to suspect a TDIF cabling issue, but that's obviously not the case, since the 2408 doesn't even show a signal to that physical output.
Is there something within the MOTU Audio Console or Cue Mix that I'm missing? I don't even have Cue Mix running, and Audio Console looks like everything is fine.
Any thoughts?
CurtZHP
Re: Missing an output on 2408MkIII using TDIF
Post by CurtZHP »
Never mind.
Figured it out. Turns out the SMPTE Console had the generator assigned to that output. The fact that I wasn't even using it notwithstanding.
:roll:
