Need a Waves L3 Alternative
I'm hoping to use the move to 64bit DP8 to finally kick Waves to the curb. The only plugin I still find essential is L3. Every once in a while I demo the competitors, but L3 always wins my little shootouts. Its been a few years since I shopped around. Can anyone recommend an alternative Limiter/Maximizer to L3. Ideally something that's 64bit.
- Prime Mover
Re: Need a Waves L3 Alternative
You talking about the Multimaximizer or just the UltraMaximizer. Because if all you're looking for is the Ultra, MOTUs standard MWLimiter is pretty close. I love the Multi, and I love Waves plugins, so I'm not trying to get rid of them, but it sounds like for you, the MWLimiter is fine.
— Eric Barker
Eel House
Eel House
Right, the MultiMaximizer is my go-to. I've tried the MWLimiter. It doesn't sound as good as the Waves Limiters to my ear. The other ones I demoed as I recall are the Sonnox Inflator, PSP Xenon, Blue Cat's limiter, the UAD Maximizer. None were as transparent as Waves'. Again, its been awhile. I probably should check out the latest versions, plus any new-comers. ...Anyone like the Izotope limiter?
Thanks for the suggestion!
Best sounding software limiter/maximizer I've found yet is the Slate FG-X. On sale this month:
http://www.slatedigital.com/products/fgx/
Blows Waves L3 out of the water IMNSHO...
(Doesn't have the multi-band component, but if you need that you can just use a DMG Equality in linear phase mode before the limiter, and voila. Or, for multi-band compression, use the very nice DDMF LinComp before the Slate FG-X: http://www.ddmf.eu/product.php?id=10)
Kubi
Kubilay Uner
http://kubilayuner.com
Kubilay Uner
Thanks for the reco Kubi. Your unhumble opinion is valuable. I'll check it out. I effing love the Slate VTM plugin!
Shall I infer from your lack of endorsement of dp8's new multi-compressor that you prefer the DMG, or have you not upgraded yet?
Kubi wrote:Best sounding software limiter/maximizer I've found yet is the Slate FG-X. On sale this month:
FG-X is great but it's also 32bit,I talked to Slate Digital tech support recently,
fwiw they "hope" to have it updated to 64bit early next year,eta sometime 1st quarter,again hopefully.
Love Slate FG-X!
Not upgraded yet. If Slate is not 64bit, I'll be a while before I go to DP8... that's Slate, SoundToys and Abbey Road that have yet to go 64.dix wrote:Shall I infer from your lack of endorsement of dp8's new multi-compressor that you prefer the DMG, or have you not upgraded yet?
Btw, the DMG EQuality is an EQ (my fav all-purpose 'non-character' EQ -- the guy who wrote it used to code for Sonalksis), not a multi band comp. I was just trying to think of alternate scenarios to make up for the lack of multi band functionality in Slate FG-X. The DDMF LinComp is a nice linear-phase multi-band that doesn't break the bank.
I'm almost ready to ditch Waves... still need an alternate for Doubler, that one comes in handy.
Kubi
Kubilay Uner
Kubilay Uner
Finally got around to getting FG-X. It failed DP 7.24's AU inspection. Bidule is also unhappy with it. It passes DP8's, but I'm not able to use 8 yet for work. Any ideas?
That's weird,I originally used FG-X in 7.24,maybe it's the OS I was in 10.68 back then.dix wrote:Finally got around to getting FG-X. It failed DP 7.24's AU inspection. Bidule is also unhappy with it. It passes DP8's, but I'm not able to use 8 yet for work. Any ideas?
Same here. Passed for me in 7.24. I was also (and still am) on Snow Leopard.kgdrum wrote:That's weird,I originally used FG-X in 7.24,maybe it's the OS I was in 10.68 back then.dix wrote:Finally got around to getting FG-X. It failed DP 7.24's AU inspection. Bidule is also unhappy with it. It passes DP8's, but I'm not able to use 8 yet for work. Any ideas?
After a re-examination today it passed inspection. Don't know what changed. Anyway, Thanks! Carry on…
Great! Cheers!!
good news! Let us know how you like it.dix wrote:After a re-examination today it passed inspection. Don't know what changed. Anyway, Thanks! Carry on…
Well, it's a real nice plugin and I'm glad I bought it, but it's no replacement for the L3. FG-X is much more about polishing and finessing your mixes than transparent limiting. I'm (still) looking for something that, ideally, I could swap with the L3 in sequences that are currently using it. In most cases where I tried that with FG-X I get a lot of aggressive "character" at best and distortion and over-saturation at worst.
