Hi,
I have a MOTU Ultralite MKIII. I've started trying to use it as a digital mixer for live performances. Currently I'm using it to mix external synthesizers with presets saved for EQ/compression for each song, while using the BUS mixes to either send or insert hardware FX. All of my software tracks are routed to the same output and mixing is done within the software for those tracks. I also have an Ipad which I'm using to control the CUEMIX. I'm feeling like this should all be sufficient and save me money on buying an expensive digital mixer that can store scenes.
The only problem I'm seeing is that I need more channels, so I'm thinking about investing in another Ultralite.
Questions:
1) If I purchase another Ultralite will this double my DSP power available?
2) Will I get twice as many BUS mixes?
3) Will all of this show up in a single CUEMIX?
Cheers,
~Airyck~
Adding second MOTU Ultralite CUEMIX question...
