LAME for DP 8
hammerman
LAME for DP 8
Post by hammerman »
Man, I wasted an hour trying to find this. For DP 8 you need a different form of LAME and in a different place. You need to get 3.98 or greater and in this form: "libmp3lame.dylib"
I got mine here: http://nuclearpixel.com/blog/view/2010- ... _osx_10.5/
Then you put it here: Library/Audio/Plug-ins/MOTU Audio Export
You can thank me later!
:banghead:
magnumpraw
Re: LAME for DP 8
Post by magnumpraw »
wow, I was literally, just going to post asking about this.
DP 8.07
Apogee Symphony Thunderbolt
Mac Pro 2013 8 Core 64 GB RAM
Re: LAME for DP 8
Thanks for that!
jbyerly1
Re: LAME for DP 8
Post by jbyerly1 »
Can this file be loaded before DP8
Mac Pro 4,1, OS 10.9.5, 2.93 GHz Quad-Core Intel Xeon, 32 GB 1066 MHz, DP 8.07, Apogee Ensemble, UA SOLO 610, Euphonix MC Control & MC mix, JBL Monitors, Ocean Way Drums Gold, Komplete 7, Waves Classic Studio Bundle,Stylus RMX, iZotope RX,1TB glyph Drive, Carvin 6 string Bass
http://www.HorizonEntertainment-NC.com
Sean Kenny
Re: LAME for DP 8
Post by Sean Kenny »
Nice one Hammerman
DP hasn't landed over here yet but I'm sure when it does, I would have grown a beard over that one!!!
Sean
hammerman wrote:Man, I wasted an hour trying to find this. For DP 8 you need a different form of LAME and in a different place. You need to get 3.98 or greater and in this form: "libmp3lame.dylib"
:banghead:
Mac Pro 3 GHz 8-Core Intel Xeon E5 - 32 GB Ram 1867 MHz DDR3 ECC - OS X 10.12.4 - DP 9.13 - RME HDSPe Madi card - iz ADA converters 24 i/o - Antelope Orion 32 i/o - Audient desk - Miller & Kreisel Monitors - Wunder Mic Pre's x 8 - very understanding wife!
http://www.ten21recordingstudios.co.uk/
Re: LAME for DP 8
It unzips into two files, do we need both? Also, the link mentions it is for: "Mac OS X 10.5 PPC, PPC64, i386 and X86_64 architectures." Excuse my ignorance, but is a Mac Pro with an Intel processor included in that?
TIA.
Re: LAME for DP 8
Is there a Framework like other versions?
Re: LAME for DP 8
'cause MOTU changed it. Ours is not to reason why, ours is but to do the voodoo that we do sooo weeeeeeell!
toodamnhip
Re: LAME for DP 8
Post by toodamnhip »
I seem to recall trying to make mp3’s in DP years ago using LAME and the mp3s kind of sucked.
They at least took Waaay longer to make and had occasional drop out, artifacts etc.This got me into many discussions on the forum about ways to change setting etc, a real pain.
Then I went to i tunes and it was fantastic. Fast, flawless, almost an industry standard.
When I see folks bothering to use DP and LAME I am truly curious as to WHY?
Is it better now?
I’d love info on this.
Mac Pro (Late 2013
2.7 GHz 12-Core Intel Xeon E5
64 GB 1866 MHz DDR3
Mojave
DP 10.13
MOTU 8pre, MTP AV, 828 mkII
Re: LAME for DP 8
It was better in DP7. I also had earlier DP versions make MP3s that were way too large.
hammerman
Re: LAME for DP 8
Post by hammerman »
MLC, he talks about 64 bit Intel architectures in the previous version here:
You don't use a framework for this one. I always had better luck with the LAME encoder quality-wise instead of iTunes, though at high quality, it can take longer. I like how I can bounce to disk as mp3 in one step.
Not easy to find the little bugger!
Re: LAME for DP 8
Thanks, I saw that but was confused as to whether he was referring to just PPC on the Macs and not including Intel processors.
doodles
Re: LAME for DP 8
Post by doodles »
toodamnhip wrote:I seem to recall trying to make mp3’s in DP years ago using LAME and the mp3s kind of sucked.
Is it better now?
well, for me, if I've got 20 files/mixes which need to be exported, it's a hell of a lot easier just exporting from DP than dragging into itunes, converting, then trying to find the bloody files in itunes and then export them all!
zed
Re: LAME for DP 8
Post by zed »
Is it better now?
First off, I use Audio Hijack Pro to capture my Mp3 mixes from DP. A great tool. It is much much easier to just engage the record button of Audio Hijack Pro and have it capture everything without futzing around with DP settings. It's an inexpensive product and the upgrades are free forever: http://rogueamoeba.com/audiohijackpro/
But secondly, I believe that you need to have LAME installed and accessible to DP (if I am remembering this correctly) if you want to import Mp3 files into DP. I sometimes drag Mp3 files onto stereo audio tracks and it works like a charm. Mono Mp3s to mono audio tracks works too. I think you have to have LAME for that, but I may be wrong. Perhaps I was trying to create an Mp3 from within DP before I purchased Audio HiJack Pro and that's why DP was asking for LAME. I'm not completely sure.
Re: LAME for DP 8
zed wrote: I use Audio Hijack Pro to capture my Mp3 mixes from DP. A great tool. It is much much easier to just engage the record button of Audio Hijack Pro and have it capture everything without futzing around with DP settings.
I have AHP as well, but what's so difficult about hitting the bounce button in DP and saving to MP3? If you have routing issues or freezing a lot of VI's is problematic, I can see AHP as a solution, but that happens in realtime with AHP. Bouncing in DP happens in virtual time and can be an immense time saver when you are sending cues or other stuff out to clients for review. A 45 minute soundtrack will take AHP 45 minutes to capture. DP will export than in probably under 5 minutes - more likely less on a faster machine.
Seriously, zed, the MP3 export and bounce from DP is really a much more efficient way to go unless you have a specific reason why a project needs to be captured externally.
