Motu Microbook II and Win7
marco75
Post by marco75 »
Hi,
does anybody knows If the Microbook II has some kind of ASIO control panel, to set latency etc... the manual talks about a "MOTU Audio Setup Console"...but I don't have it, or at least it doesn't appear to be installed. The only thing that seems installed is Cuemix-FX...any advice? :?
torrentg
Re: Motu Microbook II and Win7
Post by torrentg »
C:\Program Files\MOTU\Audio\MOTU Audio Console.exe
marco75
Post by marco75 »
It's not installed, the motu hardware setup doesn't install it for the microbook II... Is there a way to adjust latency, like in an asio control panel?
torrentg
Post by torrentg »
Check the same location, only at Program Files (x86) if you are running 64 bit.
Install latest driver from MOTU's site.
C:\Program Files (x86)\MOTU\ Audio\Motu Audio Console.exe
marco75
Post by marco75 »
Somewhere in this forum I read that there is no motu audio console for the microbook...it must be true because I can't find it anywhere.
So the question is: how do I adjust the asio driver buffer, is there a way to do it on the microbook, or it has just a fixed latency?
VigilantSound
Post by VigilantSound »
You can adjust latency buffer settings and sample rate from within the microbooks cue mix...
There is no audio console app for the micro book..
