DP and VE PRO with Lion
I just purchased a MacBook Pro with Lion. I have installed all necessary applications. I'm hosting VE Pro inside of DP 7.24. I am getting MIDI/audio across from my slave PC just fine. The issue is that to hear any MIDI/audio through my interface/monitors, the instrument (VEPro) tracks have to be set to Main Out 1-2. I can't bus them to an audio or master track. I deleted and re-added busses and outputs in the bundles menu. I don't run into the same problem when using the computer speakers. Any ideas here? So weird.
DAW: Mac Pro 3.33 Ghz i7 Hex Core / 32GB DDR3 RAM OS 10.8, DP 8.01
Slave: 2.66 Ghz i7-920 Quad Core / 24GB DDR3 RAM, Windows 7, Kontakt 5, Spectrasonics, VEPro 5
Re: DP and VE PRO with Lion
UPDATE:
When viewing the audio monitor, bus 1-2 show activity on channel 31-32 when I'm using my internal computer speakers (this is when my normal bus to audio track setup is working properly) but when I check the audio monitor while my interface/monitors are being used as output (and not working properly), the activity is on channels 43-44. This seems like a big problem. Where do I adjust the signal path? Anyone?
