Display bug
deebo
Display bug
Post by deebo »
If I have a Mach5 instance open in a project an image of it will pop up every now and again.the actual mach5 will b on my right-hand screen but a"ghost image" of a mach5 pops up on the top-left of my main screen...if i hide or call up my widgets or do anything to update the screen it disapears,even if iclick buttons that are "underneath" it,the buttons will then show thru.
I checked about 2 days ago and I was up-2-date with all my updates for OSX,DP and MACH5
Any1 else had this problem...and more NB,do you know how to fix it.
Peace love and kung fu
qo
Post by qo »
Is the entire plugin displayed in the ghost image, or just the Klingon pipes? There used to be an issue where the Klingon pipes would display in the Mixer at the exact x/y offset that they appear in the Mach5 window. This happened when the pipes became animated (e.g. when loading a preset). The symptom is the same as you describe in that you could select e.g. Mute/Solo underneath the ghost and this would refresh the Mixer display for the area occupied by these buttons.
I've not seen this at all with DP4.6 and the latest beta Mach5. What versions are you using?
deebo
Post by deebo »
Nope its the whole damn thing. If any updates have come out in the last few days I might be behind but otherwise I'm up-2-date with OSX,DP and mach5.
Have not experienced just the klingon pipes.Klingon,that funny.Have they been dubbed that or is that what MOTU actally calls them?
Nect time it happens I'll take a screen shot and ...what should I send it to MOTU.
Patricio
Post by Patricio »
you could try to Hit F11 2 times... it a temporary solution for me...
till Motu fixes this problem.
DP 10.13 , MACPRO Trashcan 2013 MACOS MOJAVE 10.4.6, Motu828X, MacBook Pro 2.1.6, MacPro, Machfive 3, Sampletank 4, Plugssound Pro,Yamaha MU128, Digitech GSP1101, MIDI Express 128, Studiophile BX8, Uviworkstation, Roland A33.OSX Motu Symphonic Instrument,Uvi Workstation. Kemper profiler Stage
deebo
Post by deebo »
yeah thanks,thats what I have been doing. when I'm running Mach5 and TC Spark FXMachine it does it every few seconds tho.really annoying.so does MOTU know about the issue?
