Hi everyone,
Thanks for all this info, its all really useful.
I notice that the first enclosure that Daniel provided the link to, also uses a Oxford chipset, which everyone tells me is the best, so if that enclosure is problematic, just finding an enclosure with an Oxford chipset (like the one I was thinking of buying) does not mean a stable enclosure.
This sure gets tricky, I think I may give the company I linked to in my post above here in the UK, a call and see what their reaction is to these issues.
Steve
Spontaneous external hard drive un-mounting
Re: Spontaneous external hard drive un-mounting
2018 3.2 GHz 6-Core Intel Core i7 16GB. External SSD Sample Drives. macOS Monterey 12.2. MOTU 624 & 8D. Cubase Pro 11, Wavelab Pro 11, DP 9.52, DSP Quattro 5. Arturia, Gforce, iZotope, NI, Plugin Alliance, Slate, SSD5, Soniccouture, Spectrasonics, Spitfire. Novation 61 SLMKII, JBL LSR 305, Sennheiser HD600, AKG 240MKII. PRS, Martin Guitars, Mensinger Bass. Vox & Orange amps. Line 6 Helix.
Some of the companies are helpful with this common problem.I bought 5 Macally enclosures last year:
Model# phi-s100sua
they run sata fw or USB and they were well reviewed and cheap($35each)
After 6 months I thought 2 drives were going south, they were both fine but after sending back the enclosures Macally immediately sent me 2 new enclosures without even checkingthem, so I think this issue is very common. Previously I had Firmtek SATA enclosures that I had issues with,simply replacing the wall wart solved the problems.wall warts fail all the time.
Model# phi-s100sua
- daniel.sneed
Just for the record: the very same erratic enclosure did work fine with 10.4.11, but was a nightmare with 10.6.8.stevenew wrote:[...]I notice that the first enclosure that Daniel provided the link to, also uses a Oxford chipset, which everyone tells me is the best, so if that enclosure is problematic, just finding an enclosure with an Oxford chipset (like the one I was thinking of buying) does not mean a stable enclosure.
This sure gets tricky, I think I may give the company I linked to in my post above here in the UK, a call and see what their reaction is to these issues. Thanks
The support men said all was fine with both OS at their place. I doubt...
dAn Shakin' all over!
