This is either a question or a suggestion for MOTU.
What I am doing:
I'm working on a song in D Major. I'm using pitch correction on the vocals. When I use the "Quantize Pitch" feature, it shifts everything to the closest exact pitch in the chromatic scale.
What I want to do:
I want to use the "Quantize Pitch" and have it shift everything to the closest pitch in a D Major scale, rather than the chromatic scale. No G-sharps, F-naturals, etc.
What I've tried:
I tried setting the Key to D Major in the conductor track. This made no difference. I looked around for an option like this...and found none.
Any other thoughts?
Thanks,
DP Fan
Pitch Quantize
Re: Pitch Quantize
Anyone have a way to quantize pitch to specific key? This would be a real timesaver.
- Dwetmaster
Re: Pitch Quantize
I believe the Transpose function (region menu) will work with audio pitching. You select all the pitches you want to change and then you apply the function.
Re: Pitch Quantize
Thanks. That's really cool that the transpose functions work for audio. I just tried it and it's helpful.
I wish there was a "contrain to scale" checkbox option when performing a regular "quantize pitch" command.
- Radiogal
Re: Pitch Quantize
You can customize Pitch Quantize (and many other things) in the "commands" window.
I have set "q" for quantize pitch and Shift + "q" for unquantize pitch.
Just my 2 cent.
Just my 2 cent.
