Mach 5 v2 - German Grand Piano glitches on playback
zandurian
Post by zandurian »
This was the case also on my old G5 dual 2.7. I thought the intel would clear things up but I can't get all the way through the playback of a song (or a "freeze track") without at least an audio glitch or two or several. The buffer is set all the way up (1024) and the cpu is idling along in DP (I'm using it as a plugin in DP). The polyphony is set to 24 and the only other patch loaded in is a flute patch.
I am running 44.1 at 24 bit. It even does it when soloed. I just tried it with the Concert grand from the universal.ufs "piano & co" and same thing so it's not patch specific. May the pianos are showing it because of the long sustain?
Any ideas?
Mac Pro (early 2009 - originally 4,1 - flashed to 5,1) 2 x 3.42 GHz 6-Core Xeon X5690, 64 gigs PC3-10600 RAM, OS 10.13.3, DP9.52, UAD2 duo, UAD2 solo,
Superior drummer 2, Mach 5-3, Ivory, PCIe 424, BL modded 24i/o, MIDI express XT, unisyn, Melodyne 2, Izotope RX2, Addictive Drums, Pianoteq
zandurian
Re: Mach 5 v2 - German Grand Piano glitches on playback
Post by zandurian »
I talked to tech support about this today - no answers yet.
twistedtom
Post by twistedtom »
Are you using the same drive to record on and store you Vi sounds on? This could choke the flow.
zandurian
Post by zandurian »
twistedtom wrote:Are you using the same drive to record on and store you Vi sounds on? This could choke the flow.
No - I'm using the internal drive for the Mach5 sounds and an external for all the recording. Any other ideas?
twistedtom
You could try some of the ideas here.
http://www.motunation.com/forum/viewtop ... =5&t=47881
zandurian
Post by zandurian »
twistedtom wrote:You could try some of the ideas here.
Thank you!!!!
