Let´s try solve the problems: what audio format do you use?
Radiogal
Post by Radiogal »
Okay, I read the Trouble/Criticism and read about all these problems about this and that, about not being able to record long files and not being able to load certain projects and files and crashes and questions what audio format ppl are using and ppl asuming this format would be better than the other.
Now Let´s do some research and try find out what ppl use and what they have experienced in this matter.
Let´s start:
I used SDII on the G5, 48 kHz/24 bits.
On the Intel Mac Pro I now use Broadcast Wave 48 kHz/24 bits.
Haven´t experienced any problems.
Who´s next?
Re: Let´s try slove the problems: what audio format do you u
Broadcast Wave 48 kHz/24 bits. No probs.
zaratero
Post by zaratero »
Broadcast Wave 48 kHz/24 bits. No problems.
http://www.cueaudio.org
Macpro 3.1 Octocore-16Gb RAM-OSX10.8 - DP 7.24
Macbook pro Core2Duo-4Gb RAM-OSX10.6 - DP 7.24
Let´s try slove the problems: what audio format do you use?
As above.
Dan Worley
Post by Dan Worley »
bWav 44.1 or 48, no problems.
c-ya,
Dan Worley
DP10.13
Dan Walsh
Post by Dan Walsh »
same as above-no probs
iMac 3.06 i3|OSX 10.6.8|8 gig ram||DP 7.24|Motu 896HD|2 Avalon VT 737's|Presonus ADL600|Slate VCC|Superior Drummer 2|EZ Drummer|1.1.6|Kontakt Player 4.1|Steven Slate Drums EX|SampleTank 2 XTAntares ATR-1|Presonus Central Station|Neumann TLM 103|Rode NT1|Audio Technica AT 4033 X2| Rode NT-5's|and lot's of other junk
AnthonyS
Re: Let´s try solve the problems: what audio format do you u
Post by AnthonyS »
iMac WAV 24/44, or 24/48 DP7.24 OSX Lion. No probs here
MacBook Pro 15" 2G QuadCore i7,8G RAM, 20"Intel iMac 2.4Ghz , 4G RAM.OSX 10.8.3 on both, DP 7.24, MOTU 828MK3, AudioBox 1818, KRK Rokit 6G2, Omnisphere 1.5, Komplete 8, Amplitube 2&3, SampleTank, Sonik Synth2, SampleMoog, SampleTron, Ivory 2, Philharmonik, EWQL MOR, SC, SOG, SD2, Reason 6, Waves, McDSP, Slate Digital VCC, FGX, Sound Toys.
stephentayler
Post by stephentayler »
I once had a problem with a long surround file..... I had left the prefs set on interleaved, and the resultant file exceeded the 2Gb limit...... once I had unchecked interleaved things were fine, the individual surround files of course were smaller (by a factor of six, of course)
Therefore it might be a good idea not to use interleaved files on longer recordings.
Cheers
Stephen
http://www.chimera-arts.com
http://ostinatomusic.com
http://stephentayler.com
cloudsplitter
Post by cloudsplitter »
I'm slightly different, since Dp introduced 32 bit float point I have been using 48/32 with no problems....I like the idea behind float point.
Mac Pro 3,1 8 core 12 gigs ram Mavericks. DP-8.05 Fractal Audio Axe-FX Ultra, motu traveler, motu MIDI express, 2-24" LCD monitors, Yamaha HS80M,Yamaha NS10M's JBL28P monitors. Mackie control universal, BFD-2, Omnisphere,Trilian Ozone 4, Melodyne Studio/Editor, . Alesis Masterlink. Avalon 737sp. PCM 90. MikTek C4V. Korg Triton Extreme. Paul Reed Smith guitars, MPC-2500 there's more..but that's the heart of it.
lgonz
Post by lgonz »
wav 48/24, crashes on long files. regular length (4min) songs are fine.
I am here: http://maps.google.com/maps?ll=25.698484,-80.160324" onclick="window.open(this.href);return false;
kassonica
Post by kassonica »
Broadcast files 96/24
Not a problem here.
Broadcast .wav 44.1/24 for most projects
All of the above. Had some problems loading files, but only when I once followed advice to use a separate non-admin OS X account dedicated to DP. In that case, files often refused to load because of permissions restrictions. There are no such problems when using the main admin account.
David Polich
Post by David Polich »
24 bit/44.1khz SDII. Export as AIFF.
Been recording in this format ever since DP 2.72. No problems (well,
a number of problems over the years, but not with the audio format).
http://www.davepolich.com
Frodo
Post by Frodo »
Wow. I was getting into "slove". That's a real internet term until it was changed in the thread. Slove is from the Urban Dictionary. Superman doesn't love. He sloves.
Sloving problems is what I live for!
