Audio Glitches
- Woody
Audio Glitches
I'm settinh up a surround recording w/ DP 4.6 G5 2 proc @ 2 gig w/ 2 Gig RAM rec on firewire drive and audio is glitching. I want to record @ 48K 24 bit but I tried 44.1 aqnd 16 bit still no luck changed buffer settings down to 128 CPU seems OK still no luck any ideas?
- Woody
Sorry I'm a new user. I'm using a MOTU 896HD audio interface, Mac G5 Dual 2 GIG, 2 Gig Ram, recording to La Cie Firewire HD I'm using Analog inputs from 896 and ADAT inputs from DA-7, monitoring thru analog outpputs 896 to Blue sky 5.1 set at direct hardware playthrough with waves platinum bundle plugins (C-1 gates on drums) and 2 band MOTU EQ on HP on everything except Kick and Bass
- Woody
I have narrowed it down to only when I am recording digital audio(ADAT and AES/EBU) with analog inputs to my 896HD total audio drop outs random timing sometimes all the way out to 45 seconds into the piece. I was beginning to suspect my DA-7 until I recorded a DAT to DP direct AES/EBU with Left Ch Clipping on DP input (the same level on DAT and also on Analog input on DA-7 and got same results)
