Chunky Questions
Chunky Questions
I just now discovered the ability to use chunks to arrange songs.
My question is this, How is the studio size affected by arranging this way? Does it need twice or triple the amount of tracks avaliable if you use two or three different chunks.
Also, is this an effective way to arrange? Are there any drawbacks to say...recording a verse in one chunk and a chorus in another.....?
thanks!
-brad
thanks!
-brad
- musicarteca
Re: Chunky Questions
If you work with multiple chunks the tracks will not add up nor will CPU processing increase for added plug-ins unless you use them in song mode.
As far as if it is a practical way of arranging that depends, if it is a long composition with very clear sections that can be worked out separately it might be very effective. You can always quickly cut and paste sections between chunks through clippings.
If you are making different arrangements of variations of a song or compositions, chunks come in very handy, for example making several versions of a radio/TV spot. Just create the original composition, duplicate the chunk and make the corresponding variations.
No, in fact, that's what it's great for. If anything, chunks are nonlinear arrangement tools; they're there so you can compose modularly.Are there any drawbacks to say...recording a verse in one chunk and a chorus in another.....?
Beyond that, Musicarteca laid it all out nicely for you.
Great. Thanks for the info.Originally posted by musicarteca:
Now...if I use these chunks in song mode...does it then effect the studio size?
thanks,
brad
- musicarteca
Yes, tracks will add up and you will be using added processing from all chunks, but you still have the nice posibility to render the song into a new sequence, and everything will be back to normal.Now...if I use these chunks in song mode...does it then effect the studio size?
<small>[ March 21, 2005, 11:51 AM: Message edited by: musicarteca ]</small>
I found freezing tracks helped with efficiency. =)
MBP i5/i7, MacOS 10.13/10.15, MOTU DP 11, Traveller, Track 16.
Dual 867Mhz G4 (MDD), APPLE 17" Display, MacOS 10.4.11, 2Gb. RAM, 4 internal drives (2 x 120 gbs./8mb cache audio drives in ATA66 bus, RAID stripe), MOTU 896HD, 4 x UAD-1, WaveArts Wavesurround Pro, DP 5.13, Reason 3.0.5, Recycle 2.1, Novation Remote 25SL, Mackie HR624, MGE ups.
