Is it possible to route audio between apps?
buddard
Post by buddard »
I'm thinking about getting the Audio Express or the Ultralite Mk3 for my home studio. I'm wondering whether it's possible to route audio from one application to another using the MOTU mixer app? I'm using Record+Reason as my main environment, but occasionally I would like to record the output from external softsynths into Record.
I know that this is possible on the Focusrite Saffire series (since they explicitly describe this scenario), but there's no mention of it in the MOTU specs. I'd prefer to go with MOTU since I'd like to use the DC-coupled outputs to control my analog stuff...
Cheers,
B$
HotShot
Re: Is it possible to route audio between apps?
Post by HotShot »
buddard wrote: I would like to record the output from external softsynths into Record.
Yes, you can do this with the MOTU drivers.
May a song always touch you in a possitive way!
SONAR X1a Producer
Windows 7 Pro 64-Bit
Intel Core i7 920, Gigabyte EX58-UD5, ATI Radeon HD 5770
MOTU UltraLite MK3, Delta 1010LT, KeyStation Pro 88, Shure KSM27, 6GB 1600MHz DDR3, 160GB, 350 GB 7200rpm HDDs, QSC K12s, Numark DDS80
At least with the Audio Express, you will not be able to to attenuate the audio from the Mac as it sits with external audio sources. It is a set volume - FULL. That is, IMO, the only thing stopping me from snagging what is (or appears to be) an otherwise exception value.
