1- Minor issue: The driver doesn't hook into the system audio so volume (and one would assume muting as well) has to be controlled from the front panel or software. If the phone rings and you want to mute the system, you have to either do it from the front panel (and the buttons are so close together that is difficult as it is) or you could turn off your speakers or presumably the AudioExpress itself, but if you are recording something and the phone rings, all you can do is turn off the speakers or fumble with the tiny volume knobs. Not a good idea in a session, IMO and awkward as it is unprofessional looking (and sounding).
2- Major issue: There is no way to control the input volume coming from the system (in the box) including from DP! Tech support this morning verified this with me and suggested I use the app(s) volume (Master fader or sub mix in DP, volume in other apps) to control this. And what about apps like Safari that may not have a volume control? S.O.L. my friends! You will get full volume and you'll have to mix everything from each individual app to balance it all. I don't think so! Not this kid!
At first I couldn't even control the main output from the front panel and had to factory reset the unit (press & hold mix and power buttons simultaneously for three seconds). And even then, it is not really clear that the switching to control the phones, mains or combo is quite as discrete as one might expect. Performance seemed a bit haphazard.
So the unit goes back to the vendor and I remain using my M-Audio FW 410. Sucks! I really wanted this puppy to work for me, but it is not to be. MOTU could not say if these will be addressed in the future. If they are, I may look at this again. In the mean time, it's back to looking at Apogee.
Sorry the news isn't better... it's hard to believe that MOTU would have put this out like this. Serious folks are not going to touch it, IMO. No mute? No system volume control? No control over how much of the system makes it into the box?! A bit more than an oversight, IMO.
