Record Dry/Monitor Wet on UltraliteMKIII
sp4rk
Post by sp4rk »
Hi!
Device description states "can even record dry while keeping a monitor mix wet for your headphone mixes" but i found no way how to do it.
I use ASIO on XP with direct monitoring from CueMix. I want to use CueMix DSP for monitor compression EQ and reverb of a vocal mic in the headphone, while recording the dry signal. My CueMix FX is pre ASIO send which makes no sense at all...
Thanks for any help!
1nput0utput
Re: Record Dry/Monitor Wet on UltraliteMKIII
Post by 1nput0utput »
Enable the effects on the UltraLite mk3 outputs, not the inputs. Then you will record "dry" inputs while hearing "wet" outputs.
sp4rk
Post by sp4rk »
As far as i know, effects can be enabled for individual hardware outputs. So like enabling an EQ for "headphone out" would make my whole headphone mix EQ-ed, right? Or am I missing something?
I just need my vocals compressed to the headphones, not the whole mix.
Thanks for the answer!
1nput0utput
sp4rk wrote:As far as i know, effects can be enabled for individual hardware outputs. So like enabling an EQ for "headphone out" would make my whole headphone mix EQ-ed, right?
Yes, that's right.
Or you could route the mic input to an unused output pair in the UltraLite mk3's on-board mixer, enabled a compressor on that output, set the Return Assign parameter to that output pair, and then record "wet" Return 1 or Return 2 in the DAW program alongside the "dry" mic input. It's convoluted, but it would work. There may be a better solution, but I can't think of it right now.
Bitten75
Post by Bitten75 »
1nput0utput wrote: Yes, that's right.
The EQ can also balance the volume of the bass as well as the tremble of the music to have a nice sound through the Klipsch headphone. On the other hand rerouting the Mic input for the on-board mixer is a bit complicated for me. But I will still stick with EQ for a better result.
