OMF (all types and formats) crashes DP 7.21 on a dual G5
bralston
Re: OMF (all types and formats) crashes DP 7.21 on a dual G5
Post by bralston »
martian wrote: we use OMF all the time receiving picture cuts - if it didn't work I wouldn't be using DP.
altho I have to use the very expensive AVtransfer alot ( 800us$!!!!!!!)
Yeah...too bad AVTransfer was declared "End-of-Life" and Fairlight announced a week ago (11.13.2010) they have ceased development. ugh!
Regards,
Brian Ralston
anapena
Post by anapena »
My ways to import OMF files are to try older versions of DP. Yesterday found out that I had to dig my old G4 and DP4 to get OMF imported properly. Of course I start with DP7, but if I have to, then 6, 5, 4 and 3 is still in te box... :roll:
Long time ago I used also old Nuendo as omf tool, import and export thru it, then DP4.
Nowadays I have Logic 8 which handles that part too if needed. Import OMF into Logic, export as AAF to DP... :shake:
OMF as a standard should be dumped into the deepest swamp and then invent new and better standard to replace it. :smash: Anyone knows if is this already happening?
