Possible workaround bundle mess
Hi guys,
Most of you are probably aware of the messed up bundles. When opening a project all the input bundles seems to be inactive.. For me with Vienna Ensemble Pro. I always change it back manually to the correct inputs.
But here it is - when I opened up a project with inactive bundles I immediately did a short offline bounce. This resulted in reappearing bundles again! Really strange and may be just incidentally but it worked for two projects for me now! Just select one bar - bounce to disk - hit enter and even cancelling it will do it.
Still it's not perfect but until there is a fix, this works for me and hopefully also for you guys.
Save
Save
- Len
DAW Mac Pro 6-core 2013 | 64Gb RAM | 10.11.6 | Metric Halo ULN-8
DP 9.5 | VE Pro 6 | Kontakt 5
Re: Possible workaround bundle mess
Worked for me when I chose "do not import"; when I chose "add to soundbites window" (which I usually have the Bounce To Disk menu set to), it didn't work. But thanks for the tip!
Mac Studio M2 Ultra 128G RAM OSX 14.3, 16" MacBook Pro M1 Max, UA Apollo x6, UA Apollo Twin, UAD-2 Satellite (x2)
Worked for me also...just bounced one bar of an empty template with messed up bundles, bundles were fixed, hit undo after the bounce and the bounce disappeared but the bundles stayed. Great find!
- Dan Worley
What a find, indeed. This may lead to getting this problem fixed once and for all. Right on!!! Thanks!!!
c-ya,
Dan Worley
c-ya,
Dan Worley
DP10.13
Interesting!
We should make a quick note of this to MOTU. It might help them with programming the permanent fix for this issue.
Holy Mackerel. Your workaround works!! That is totally crazy!!!!
How I tested it: I created a new session from a template and the inputs showed up italicized like usual. I selected one measure, bounced and after the bounce, everything came back setup properly.....!!!!! I've closed and reopened the session twice and it keeps re-opening properly..........INSANE!!!!
(FWIW, my recreated template saved as a Stationary Pad continues to hold up.)
Anyway, thanks for that one! I hope your clue can help get MOTU one step closer to solving this very strange issue.
-gabe
-gabe
Computer: 2019 Mac Pro 28-core 2.5gHz, OS 10.15.2, 96GB ram, all SSD/NVME drives, MH Labs ULN-8, MOTU MidiTimepiece AV
DP Setup: DP10.11, all Spectrasonics VIs, all Waves plugins, Sonnox AU, Altiverb, NI Komplete 12/K5+6, Plogue Bidule 64 as VI host
...or maybe they can just make available a command key to bounce an empty bar.Gabe S. wrote:
cmlcwbbj
Tim wrote:...or maybe they can just make available a command key to bounce an empty bar.Gabe S. wrote:
...On startup!
God bless you OLB.
8.07 64bit, Spire, Nexus, Fab FilterDiva, Gladiator, Nexus, Sylenth, Stylus RMX, Live 9, Reason 6.5, Komplete 8, AD Keys, AD Drums, Geist, Ivory, Waves 9 Mercury, Sound Toys, Fab, VEPro, Reason, Live, UAD2, x3 2408mk3, PCI424, MAC PRO Dual 3.46 Ghz 12 core Intel Xeon, Memory: 64gb ram, MAC OS X: 10.8.6
Yes. That seems to work. Thanks.delcosmos wrote:God bless you OLB.
Computer/s: OSX 10.8.3
2 x 2.66 GHz Mac Pro Quad-Core Intel Xeon w/ 16GB RAM,
DAW:DP8.05
Hardware: Apogee Duet
VI's/Plug-ins:
Kontakt 5.1, EW PLAY Libraries and a
million others.
DAW:DP8.05
VI's/Plug-ins:
million others.
Working for me. Thanks, this is a huge help.
DS
DS
this is working for me as well, I just tried it and my inactive bundles(aux sends from VEP) miraculously sprang to reverb giving life!!!
What's happened to me a couple of times in the last couple of days is the inputs show up active but from a completely different source. In my case, my template has Stylus and Omnisphere and also an aux channel set up for Ableton Live (rewire). My Stylus inputs have sometimes opened as Ableton inputs, so obviously the BTD trick won't work in this case.
- Dan Worley
Did you try it? It's unlikely, but maybe it would set them straight. Worth a shot.dinobass wrote:What's happened to me a couple of times in the last couple of days is the inputs show up active but from a completely different source. In my case, my template has Stylus and Omnisphere and also an aux channel set up for Ableton Live (rewire). My Stylus inputs have sometimes opened as Ableton inputs, so obviously the BTD trick won't work in this case.
c-ya,
Dan Worley
DP10.13
Yeah, I tried it and no go.Dan Worley wrote:Did you try it? It's unlikely, but maybe it would set them straight. Worth a shot.dinobass wrote:What's happened to me a couple of times in the last couple of days is the inputs show up active but from a completely different source. In my case, my template has Stylus and Omnisphere and also an aux channel set up for Ableton Live (rewire). My Stylus inputs have sometimes opened as Ableton inputs, so obviously the BTD trick won't work in this case.
c-ya,
Dan Worley
