I have this problem :
I have the old MTP AV, serial version.
I want to connect my MTP on XP32 (sp2) into the parallel port.
I downloaded the drivers from MOTU site.
I start the intallation but the PC sees the MTP as a PC FLYER.
the control panel does not see the MTP AV.
I have(also)the old driver for windows 95 but I do not think that can use it on XP.
you give me a working driver and the right procedure to configure the PC?
thanks
MIDI TIMEPIECE av (SERIAL) on XP32
Re: MIDI TIMEPIECE av (SERIAL) on XP32
I have a similar problem. I have the same tools but my PC sees the interface as a MOTU MIDI DEVICE (PC Flyer a: / b:), never MIDI timepiece av.
If I try to install the downloaded driver saying: Can not load the driver for MTP AV. driver files missing. reinstall the driver or contact your system administrator.
What should I do?
What should I do?
