Omnisphere, RMX, Trilian Users!
Has anyone else noticed that the option to run spectrasonics VI's
"in realtime" no longer exists?
not sure if why,..but try all 3 and see.
can't be good news, since spec suggests that's the way to run them in DP.
Mac Pro Quad 2.66|9GB|Macbook Pro dual core 2.4|4GB|
OS 10.6.4|DP 7.21|Apogee Ensemble & Duet|
Re: Omnisphere, RMX, Trilian Users!
It's still here in my copy of Stylus RMX. Version 1.9.4d (32 bit) of Stylus running on DP 7.21.minimoog wrote:Has anyone else noticed that the option to run spectrasonics VI's
What version of DP are you using? If the problem is that the menu isn't opening where the options appear, Ctrl-Click the gray oval in the title bar of the plug-in window at the upper right to see the menu.
thanks James, latest versions of everything,...I didn't know I had to ctrl click to see the options to run realtime,.that was it.
It didn't used to be that way, the lil mini menu used to drop down.
thx for the help though!
It *shouldn't* be that way. There's a graphic glitch with the Spectrasonics stuff that needs to be fixed. Ctrl-Clicking the oval is a workaround until it gets sorted out and the mini menu works again with those plugs.minimoog wrote:thanks James, latest versions of everything,...I didn't know I had to ctrl click to see the options to run realtime,.that was it.
oooohhhh!
ok
thx
ok
thx
Thanks for the tip, James!
Bob
DP 11.23
Metric Halo ULN-8 mk4
DP 11.23
James, if you haven't already done so, please report this problem to MOTU. Thanks.
Glenn O
Spectrasonics
Glenn O
Spectrasonics
Hey Glenn... they're aware of it and I'm pretty sure they're working on a fix on their end.GlennO wrote:James, if you haven't already done so, please report this problem to MOTU. Thanks.
