change Meter, while preserving the MIDI
kassonica
Re: change Meter, while preserving the MIDI
Post by kassonica »
Kubi wrote:Yes, I was surprised to hear Mr Tech Support there said it 'cant be done'.
Maybe time for him to :rtfmmad: ???
:mrgreen: :mrgreen: :mrgreen: :mrgreen:
:rofl: :rofl: :rofl: :rofl: :dance: :rofl: :rofl: :rofl:
Post by Shooshie »
Maybe what the Tech Support person meant was that "it can't be done without a lot of explanation, and I'm too tired to explain it." I mean, you have to grant that it's not easy being a tech support person. But that's been doable since the beginning. I always had a QuicKeys command for opening the calculator, because I had to use it so often for time shifts, meter changes, compressing velocities, and probably other things I can't think of right now. Most of those things have been improved so that we no longer need the calculator. For example, in time scaling we can use percentages or actual measures/beats/ticks for where we want it to arrive. But they have not improved meter changes from duple to triple or vice-versa.
But then, it's not everyone who needs to know how to do so. I can see how some of these things get shoved to the back burner. This one seems kind of big, though. Glad to see that I'm not the only one who has had the problem or who has come up with the solution! Good going, Kubi!
Kubi
Post by Kubi »
erikjamesmusic wrote: I DID have to realign all 20 of my markers, however. All in all, easy, breezy.
You could have locked the Markers, too! (In the Marker window.) Then they would have stuck to their absolute time positions and you wouldn't have had to realign them either. :D
williemyers
Post by williemyers »
erikjamesmusic wrote:Does anyone know of a workaround? Or should I try to conquer this in Sibelius?
erikjamesmusic wrote:It took me about 20 minutes to accomplish, however,
Erik, glad you were able to work this out.
erikjamesmusic wrote:For future reference,
I don't know the length of your peice, but "For future reference", it would've taken Sibelius about 2-3 minutes to do it for you.... :wink:
Kurz Midiboard, MOTU MTP AV
https://vimeo.com/71580152
~me
erikjamesmusic
Post by erikjamesmusic »
How would you go about this task in Sibelius. It would've taken me 3 minutes to accomplish in DP as well, but I had about 20 meter changes and I had to change every single one to either 12/8 or 6/8.
I forgot about LOCKED markers, kubi! DUH.
Mac Pro 8-core 2.8, 10g RAM, OS 10.6.4, DP 7.22, MOTU 828mk3, UAD-2 Duo, Dynaudio BM5-As, Nord E3-73, Kurzweil PC3-X, Mackie Control Universal, NI Komplete 7/Kore 2, PLAY 2 (most libraries), Spectrasonics, Altiverb, Vir2, etc...
williemyers
erikjamesmusic wrote:How would you go about this task in Sibelius?
erik, sorry to be a bit late responding. I've done this very thing, but not in a while. but in a nutshell (if memory's correct), I would import the DP MIDI file - with it's 4/4 & 2/4 meters & markers - in to Sib.
Then, at the top of the Sib. score, I would insert a 12/8 time sig. and Sib. would re-bar the entire piece in to 12/8.
Then I would find the spots where 6/8 was needed and "select" those notes and do a "6/8 time sig.".
Sib. will put just that selection in to 6/8 and leave all of the following in 12/8.
Then repeat as necessary.
~me
FREIMUZIC
Post by FREIMUZIC »
THANKS SO MUCH FOR THIS POST!!! Just saved my life!!
Happy Thanksgiving!
Tritonemusic
Post by Tritonemusic »
It's so cool to see that a 10-year old post still has value, and can bring joy to a Unicorn in need. :unicorn: :koolaid:
