SQ: Anyone here have and using the QuickSilver G4
Just curious if you have and are using a QuickSilver PowerMac G4.
How do you like it and does it do the job with DP and other sequencer programmes ?
Mac OS: Mojave
Re: SQ: Anyone here have and using the QuickSilver G4
Up until about a month ago I had an 867mhz Single G4 quicksilver. It ran great, and with 1.5gigs of ram, it was a pretty good machine. I recorded alot with dp4.52 on it, and could get about 20 tracks going with about 2 plugs each with no problem. I recently bought a new powerbook for the portability.
Powerbook G4 1.67ghz (15"), 828mkII, rockit 8 monitors, and lots of coffee on those long late night sessions.
Thanks for your reply/interest in my post.
Actually I went ahead and purchased the QuickSilver G4 dual 1 Gig cpu with 1.5 GB RAM.
At this time I still have to tweek some preference settings in DP 4.52 ( PANTHER ) because I am having some crashing. Although they are never consistent as to what I do with DP.
Maybe my system preference settings have to tweeked.
When I figure that one out I'll take it for a ride in TIGER which I have installed on another internal hard drive.
Never had that problem with my G4 dual 450 Mhz process with 1.5 GB RAM.
Mac OS: Mojave
- yofo
I have a Quicksilver G4 running OSX 10.3 and it crashes more since I upgraded to DP 4.52. Maby I need 10.4.
Mac OSX 10.6.8 2 x 2.66 GHz dual-core Intel Xeon 8GB 667 MHz DDR2 FB-DIMM RME Fireface 800
- terra
the best option for you, is : https://secure1.sonnettech.com/product_info.php?cPath=22_26&products_id=48&osCsid=7bf19d36dbc00bb51f43fcb169fe0d15
G4 1.4 Mhz/ 1.5 Gb RAM - iMac 2.1Gh 1.5 Gb RAM - 828 MKII - MTP/AV - DP3 - 2 (Two) SAMPLECELL Cards - MACKIE 32/8 Bus - JBL4333A - YAMAHA NS10M - YAMAHA ProR3 - DBX 160A - OTARI DAT - ADAT XT - VIRUS - TRINITY - Super JD 990 - MO'PHATT - POD Line 6 - BEHRINGER's DEQ2496 / MIC2200 - NEUMANN MIC's and more...
Or DP 4.6....Originally posted by yofo:
Mac Pro 5,1 12-core 2.4 GHz//40GB RAM//RX 560//macOS 10.13.6//SSDs//MOTU 896//Keylab 88//Faderport 8
Pro Tools 2018.7//LPX 10.4.1//DP 9.51
NI Komplete Ultimate 11//Albion One//Soundiron Choirs//Pianoteq//Analog Lab//VSL SE & Chamber Strings//etc
Using a G4 Quicksilver with 1.5 GB ram and all is stable here. DP 4.6, OS 10.3.9. Also using battery 2, autotune 4, EWQL silver edition, no crashes. Not running very high track counts 15 to 30,some waves plugs,plus MIDI. All is good. Tried the MX 4 demo and some presets maxed out the CPU and an organ patch on EWQL did the same. Otherwise still a very usable machine.
Well folks the problem with me QuickSilver was "heat"!
My mac tech guy installed a couple of external fans. He showed me that the design in the early versions of QuickSilver were stupid. For example placement of the video card prevented all the fan power to be directed at the heat sink. Also the fan has a difficult time of drawing IN air because the case does not have any grill screen to allow outside air to flow in. It's a beautifull case but poorly designed.
Mac OS: Mojave
Using a 2001 Quciksilver with a Sonnet 1.4 gHz processor and 1.25 GB RAM and about 140GB of internal drives with another 60GB+ FireWire drives. Running current Mac OS 10.4.2 and DP 4.6 with MachFive and MX4 (flat screen 19" Viewsonic).
Runs like a charm. Heat is not an issue whatsoever, even with loaded PCI slots.
Just lucky, I guess.
<small>[ July 16, 2005, 09:36 PM: Message edited by: MIDI Life Crisis ]</small>
- terra
how you installed its Sonnet Upgrade ? left all the Softwares and the Oprational System or had that to install everything again ? I have a same G4 867 single... and am buying a Sonnet 1,4... I am enough to change the Processor (CPU) or I have that to make some thing before ? I thank its reply.
Well folks my mac tech guy is rebuilding this QuickSilver.
He had to install a new superdrive.
It was obvious that the original superdrive was abused/overused and also fairly old technology trying to run in Panther and Tiger.
Mac OS: Mojave
Your's must have been the first revision. I got my dual gig Quicksilver right after the mirror door model came out and have had none of the problems you mention. Works great. DP 4.6 & OSX.3.9.
