James Steele wrote:Right... because you're entering a value, not a mathematical operation from what I understand. If your bite gain was -3.00 and you click and type in +4.00 it's now SET to +4.00. You've in essence added 7.00 db of gain going from -3 to +4. At least that's what I am understanding.
Yes indeed James, got it.
It can take a while, but over here, the penny has finally dropped.
G.
Mac mini M1, 14.7, 16gigs RAM, 828 mk3 Hybrid, DP 11.31, Various VIs
martian wrote:please please mr motu - can we have bite gain maths - make it 11 louder - make these clips 11 louder,,, that will make PT'er's even greener!
bite gain rocks!
It would be a nice feature. Also a "Normalize Bite Gain" feature too. But both as a new shortcuts, I like the current dialog box of "Set Bite Gain".
OS Mavericks (10.9.5)
Protools HD Native 11. Logic Pro 9. Digital Performer 8.
Waves 9 Mercury Bundle. iZotope RX 3 Advanced.
Avid HD OMNI. Apogee Ensemble.
I use Set Bite Gain all the time!!! I use it a lot when editing and mixing. I even made a user short cut command for it It´s so much faster than the volume automation and it let´s me set the track O/P levels to my mixing console in a very quick and easy way. I prefere it over the TRIM plugin for gain staging. AND I love the fact the audio wave is showing it´s volume. It´s so much easier to set volumes just by the graphics
Paging Magic Dave, this brings up an interesting question - we know the trim plug uses the full dynamic range of the 32bit float resolution. What's the resolution used when using Set Bite Gain/Set Bite Volume instead...?
My guess is the same, since it's a non-destructive process, but would love some verification here... Thanks!
Kubi wrote:Paging Magic Dave, this brings up an interesting question - we know the trim plug uses the full dynamic range of the 32bit float resolution. What's the resolution used when using Set Bite Gain/Set Bite Volume instead...?
I´d say that it is floating point too, you can clip the graph and pull down the fader and it won´t distort. How tricky is digital audio, ain´t it? I only seem to lengthen the "for check" list for years, even though I sometimes do check things .
Bite Gain rules for OMF material and is a must in my workflow to keep the compressors running smooth.
zaratero wrote:
Also somebody asked: Bite Gain is pre insertion point, Bite volume is post.
Er......what's this mean exactly? Not sure what "insertion point" is.
Just what the words say : Along the signal path, bite gain is placed just before any mixer insert, while bite volume is placed just after mixer inserts. That is to say, if you play a soundbite, you'll hear, and see, bite gain action while setting parameters in an insert window, but not bite volume action, which happens later in the signal path. Hope this makes sense, gavspen.
