Full Image
Ooooh Nostalgia.. forgot all about that one.amplidood wrote:Starting to just throw everything into the pot and let it simmer slowly....
Nostalgia 72 dev
Which is precisely why the DefaultStyle.xml guide exists and will be updated for 7.2corbo-billy wrote:I appreciate this Oxydized Themes but there is not enough contrast in general and we can't use the color brown or dark orange for the capture, files and waveforms.
Oxydized would seem perfect with a lighter background (broken white) on Sequences, Tracks, Sounbites windows.
I have used Oxidized for… I don't remember... a year? However long it has been out for previous versions of DP. It is my favorite, and my standard mod. (er… Themes, we call them now) There is no problem with the Oxidized Theme in regard to anything in DP (soundfiles or otherwise), and the contrast is excellent, and the color is simply irresistible and easy on the eyes over long periods of time. Even when I temporarily switch to the beautiful and amazing "Sleek" that Andy has recently re-released for 7.2, I still have to return to Oxidized. It's just unbelievable.corbo-billy wrote:I appreciate this Oxydized Themes but there is not enough contrast in general and we can't use the color brown or dark orange for the capture, files and waveforms.
That is definitely improved, but where are you going to put those 5 pixels when the windows are integrated into the Consolidated Window? Or when the single window is expanded? If they could come up with a way to ADD them when the single window is closed, that would be good, but I don't want to give up 5 pixels per pane of the CW. And since I keep my main edit windows open full-screen anyway, in separate "Spaces," I just cover the title-bar with the Control Panel and Shortcuts Window. Works for me, but I'm with you in a desire for that space, if it could be made to disappear when not needed.amplidood wrote:A very well expounded explanation of the issue. Thanks Shoosh.
After reading through that, the solution actually seems very simple. Single windows (with collapsed tab bars) simply need about 5-10 pixels extra below the title bars in order to keep the Info Bars from butting up against them.
So instead of this...
...we'd have this
A huge difference in clarity.
