running dp7 with pro tools 8 hd?
I've just added Pro tools HD to the studio. So far, it's fine, but I love digital performers tuning features. I've tried melodyne, and autotune, but I hate them all. I love dp for minor pitch adjustments.
Is there anyway to run Dp synced to pro tools so that I can use some of dp's features?
thanks
thanks
Mac 2.66 quad, DP 7, Latest Snow Leopard, Aurora 16.
Re: running dp7 with pro tools 8 hd?
Would dae mode do what you want? As I understand it that would allow DP to be used as a front end for PT - I've not tried it on my cousin's PT system which is my PT access. I do believe there's a particular order for installation of the programs for this to work - PT installed and updated first and THEN DP installed. If done the other way around DP has to be re-installed after PT is installed.cchord59 wrote:I've just added Pro tools HD to the studio. So far, it's fine, but I love digital performers tuning features. I've tried melodyne, and autotune, but I hate them all. I love dp for minor pitch adjustments.
thanks
What is your hardware setup?cchord59 wrote: Is there anyway to run Dp synced to pro tools so that I can use some of dp's features?
thanks
I sometimes have DP - using my Traveler - and PT - using my MBox 2 at the same time. They are synced by MIDI clock between the 2 hardware units. I tend to monitor out of the MOTU, and have the MBox connected to CueMix via spdif.
I can either do this on one computer, or my Mac Pro and MacBook Pro together.
Cheers
Stephen
http://www.chimera-arts.com
http://ostinatomusic.com
http://stephentayler.com
I'm running an aurora 16 with protools hd 2.stephentayler wrote:What is your hardware setup?cchord59 wrote: Is there anyway to run Dp synced to pro tools so that I can use some of dp's features?
thanks
Cheers
Stephen
I've tried getting to get dp to run in DAE, but it crashes everytime I enter DAE.n2mpujack wrote:Would dae mode do what you want? As I understand it that would allow DP to be used as a front end for PT - I've not tried it on my cousin's PT system which is my PT access. I do believe there's a particular order for installation of the programs for this to work - PT installed and updated first and THEN DP installed. If done the other way around DP has to be re-installed after PT is installed.cchord59 wrote:I've just added Pro tools HD to the studio. So far, it's fine, but I love digital performers tuning features. I've tried melodyne, and autotune, but I hate them all. I love dp for minor pitch adjustments.
thanks
Did you do the install like I mentioned: install PT & latest updates and then install DP? That's the order. You may want to get a hold of tripit on here as he is running both systems; he might be able to help.cchord59 wrote:
I heard something about Avid dropping DAE support. Is that true and how will that affect using DP with PT?
Theoretically that's true but how to account for this from MOTU:Phil O wrote:I heard something about Avid dropping DAE support. Is that true and how will that affect using DP with PT?
http://www.motu.com/products/software/d ... ools.html/" onclick="window.open(this.href);return false;
wherein it's stated that PT & DP will play well with each other?
I know it says for PT8.0.3 but I think this page was written before PT8.0.4
That's what I'm thinking. I Installed PT then DP the way I'm supposed to, But I'm wondering if Things got messed up with PT 8.0.4n2mpujack wrote:Theoretically that's true but how to account for this from MOTU:Phil O wrote:I heard something about Avid dropping DAE support. Is that true and how will that affect using DP with PT?
here's a bit more from MOTU
http://www.motu.com/techsupport/technot ... erformer-7" onclick="window.open(this.href);return false;
and yes, if you click the "compatibility" link, MOTU's only showing up to and incl. 8.0.3 as compatible (so far...)
Kurz Midiboard, MOTU MTP AV
https://vimeo.com/71580152
~me
~me
Anybody know when that page was written? PT 8.0.4 dropped on June 8 and DP7.2 rolled out July 16 for reference.williemyers wrote:here's a bit more from MOTU
