I Can't "Shift" Select in 7.1
Back in all other versions of DP, I could hold shift and select individual tracks. For example, I could select track one and four. Now, if I try to do that, I get tracks 1-4. I can't find a way around it. I have searched the prefs but nothing is ringing a bell.
If I want to bounce only certain tracks, I have to drag them around so that they are adjacent. This can't be what Motu had in mind. Can anybody help?
Re: I Can't "Shift" Select in 7.1
Command-click.
DP8.06 PT11.2.0 VEP 5.3.x
Try Command Select, Shift Select always chooses a range even in the Finder, Command Select chooses individual selections
Cheers
Stephen
Cheers
Stephen
http://www.chimera-arts.com
http://ostinatomusic.com
http://stephentayler.com
Thank you guys! Consider this topic resolved!
- Shooshie
I think the rule within DP is something like "lists use Command-Click (or drag), while data use Shift-Click."
Shoosh
Shoosh
- buzzsmith
This came up before. It's a Mac OSX thing, right?
I remember that it used to be Shift-Click to "jump over" some items in a list, but now it's Command-Click system wide, I believe.
Buzzy
Buzzy
Yamaha C7 Conservatory Grand
Hammond B-3 / Leslie 145
Focal Twin6 Be(s)
Focal Twin6 Be(s)
I believe that it was in the DP update/upgrade notes a while back stating that they were changing this to more conform to the OS and other apps usage.buzzsmith wrote:This came up before. It's a Mac OSX thing, right?
Buzzy
I think that was the memo I missed! I went from DP 5 to DP 7.1. I swear I used the shift click for this function before, but it is fine with the command click now. Especially since I know how it is done.NazRat wrote:I believe that it was in the DP update/upgrade notes a while back stating that they were changing this to more conform to the OS and other apps usage.buzzsmith wrote:This came up before. It's a Mac OSX thing, right?
Buzzy
