How to Get DP7 to recognize Patch Lists
I did this so long ago, but now I'm reinstalling everything from scratch (clean install mistake) and can't find out how to get DP to see the Roland patch lists. I did a search here but couldn't find it.
MacPro5,1 6-Core Intel Xeon, Processor Speed: 3.46 GHz
Number of Processors: 1
Total Number of Cores: 6
L2 Cache (per Core): 256 KB
L3 Cache: 12 MB
Memory: 32 GB. Mojave. DP 9 and Apogee Duet.
L3 Cache: 12 MB
Re: How to Get DP7 to recognize Patch Lists
Are you sure the files are in the correct location? You should have one file named "Roland.middev" and other files named "<Model Name>.midnam."
<Boot HD>/Library/Audio/MIDI Devices/MOTU/Roland/
If they are, try this:
Open Audio MIDI Setup. Delete those instruments for which no new patchlists appear. Close AMS and relaunch it. Now add back in the instruments you deleted. Be sure you enter the correct System Exclusive ID number for each device.
Kind regards.
Kind regards.
Dave Bourke
– ideation –
Mac Pro Quad Xeon 2.66 GHz, 5 Gb, OS X 10.5.8, iMac 24" 2.4 GHz Intel Core Duo, OS X 10.6.2, Mac G4 dual 800 MHz Quicksilver, DP 7.11, PCIe-424/24i, UAD-2 Quad/UAD-1e, PowerCore Firewire.
– ideation –
- buzzsmith
If Dave's procedure works, great!
If not, I have a step by step guide that the "Cherry Picker" app guy sent me that allowed me to restore one set of patch lists that were missing just a few days ago. (Roland, too)
I'm not on my studio Mac, right now, or I'd post it.
It involved what Dave said, but it also involved quitting and restarting DP, as well, a couple of times.
Lemme know if you need it.
Buzzy
Buzzy
Yamaha C7 Conservatory Grand
Hammond B-3 / Leslie 145
Focal Twin6 Be(s)
Focal Twin6 Be(s)
- cloudsplitter
buzzsmith wrote:If Dave's procedure works, great!
Buzzy
Buzz, I would be interested in that, I have Cherry Picker also but have
been unsuccesful in making it work
Mac Pro 3,1 8 core 12 gigs ram Mavericks. DP-8.05 Fractal Audio Axe-FX Ultra, motu traveler, motu MIDI express, 2-24" LCD monitors, Yamaha HS80M,Yamaha NS10M's JBL28P monitors. Mackie control universal, BFD-2, Omnisphere,Trilian Ozone 4, Melodyne Studio/Editor, . Alesis Masterlink. Avalon 737sp. PCM 90. MikTek C4V. Korg Triton Extreme. Paul Reed Smith guitars, MPC-2500 there's more..but that's the heart of it.
The patch lists are in the right place. Before I delete the devices in Audio/MIDI setup, I noticed the one synth had a system exclusive ID of 0. The others were missing.
How do I know what id to input?
L3 Cache: 12 MB
L3 Cache: 12 MB
Another curious thing I just noticed. Some of the midnam files are gray icons with the word "exec" in green on it. Others look more like text files that can be opened.
Does that matter?
Does that matter?
L3 Cache: 12 MB
L3 Cache: 12 MB
OK. My mistake.
I DO have the patchlists. I DON'T have the expansion card lists.
So I'm assuming there's a place to get them and put them in the same folder as the main lists?
I had this working for years and this is the first time I've had to do it again so it's totally foreign to me again.
L3 Cache: 12 MB
L3 Cache: 12 MB
I Just caught something from another thread and gave it a shot and it worked.
You go to Bundles and click on the synth. Then Edit. Then a MIDI device Properties window opens and you pick Patches.
There you can pick the list that fits what you have. The only tricky part is it doesn't say in that window what slot it's talking about so I had to do the old trial and error. But it looks like everything is fine now.
L3 Cache: 12 MB
L3 Cache: 12 MB
- buzzsmith
Cool!
Focal Twin6 Be(s)
Focal Twin6 Be(s)
- buzzsmith
For others...(in this case my Proteus 2000-substitute your devices)
I would do the following to force DP to see the updates:
1) Quit DP, and trash your Proteus 2000.midnam
2) Expand the included file, and put it into the /Library/Audio/MIDI Devices/MOTU/E-mu Systems folder <Not necessary-Rob sent me the 2000 patch list>
3) Start AMS, delete your Proteus 2000 device, and quit AMS
4) Start up DP, and Quit once it has opened
5) Start AMS, add a new device, and make sure you select E-Mu Systems and Proteus 2000 from the Pop-up menus. Wire it up
6) Start up DP again - you should see the patches!
Rob
Buzzy
Rob
Buzzy
Focal Twin6 Be(s)
Focal Twin6 Be(s)
