Mastering project / Soundbites problem…
- MattDNP
Technical question for DP 4.61 on a Mac:
I'm creating a Mastering project...I'm importing about 16 hours of audio in total. I can not slide the Soundbites to the right past a certain point in time...they disappear from the Sequencer window...they simply won't show up.
I still have a few more files to import, but can't...until I get this cleared up.
Is there a global time limit on DP, or a preference I can control/expand it?
HELP!!
Thanks,
Matt
HELP!!
Thanks,
Matt
Peace,
Matt
Matt
Re: Mastering project / Soundbites problem…
Hi
If you change the sequence length to desired your Soundbites should
fit in. I hope this helps.
jarok
jarok
http://www.facebook.com/pages/Trio-Trout/140467307206" onclick="window.open(this.href);return false;
- MattDNP
Change the sequence length...thanks!
Would love to do this, but just *how*, please? Could not find answer in Help.
M
M
Peace,
Matt
Matt
- kassonica
I take it you have the manual???MattDNP wrote:Change the sequence length...thanks!
M
kassonica wrote:I take it you have the manual???MattDNP wrote:Change the sequence length...thanks!
M
- MattDNP
yes, gentlemen...I have the manual...am legit owner...just looked for answer in DP desktop Help and didn't see.
Thanks for pointing me in the right direction...I'll go RTM
M
M
Peace,
Matt
Matt
You only got a M with your version? I got a FM with mine - must have paid more.MattDNP wrote:Thanks for pointing me in the right direction...I'll go RTM
M
DP8.06 PT11.2.0 VEP 5.3.x
- MattDNP
thinking FM, writing 'M'...playing nice!
hey, I STILL can't find anything about how to simply increase the Sequence lengths? After reading the manual...;-(
Could someone please simply tell me how to do this?
Peace,
Matt
Matt
Can you place the soundbites with the Shift (Command-L) function?
- MattDNP
Thanks, Tim...
I can drag all the Soundbites into the Sequence Editor window and move around. The problem arises when I try to drag past 6 hours or so. I am Mastering a total of 62 tracks…each track is 15 minutes. (I know there are probably other software packages that would do a better job, but I'm novice enough that DP will work for my needs).
I had all but the last ten or so entered, but need to move ALL of the existing files over to the right. When I manually drag a soundbite, it disappears from the Sequence Editor window entirely. I can 'see' it's still there in the Tracks window, but I can't seem to grab it or see it.
Sorry…I'm a musician learning to be an engineer in my home studio...
Peace,
Matt
Matt
Check out the "chunks window"in the manual. This might help.
Macbook 2GHz Core 2 duo 2G memory Ultralite DP 7.24 OS 10.6.8
- MattDNP
Thanks folks for all the helpful suggestions...will give it a try...
Peace,
Matt
Matt
