What is your main Vocal mic
builder
Post by builder »
I am in the mists of trying to decide what vocal mic to get.
Right now I use a Rode NTK primarily, a Shure SM7, and also an AKG C414-XLS.
I am considering the Soundelux U195 or maybe an AEA R84 for a different flavor.
What kind are you using?
Suggestions are appreciated.
Music - http://www.missingpalmerwest.com/Missin ... songs.html
Dual 2.0 G5 (Rev. A), 4.5 GB Ram, Powerbook 1.5 GHZ 1.5 GB Ram, (BLA) 828mkII, UAD-1 X2 , 10.4.8, DP 5.13, Sebatron VMP2000e, Sytek MPA, Many Mics
logo80
Re: What is your main Vocal mic
Post by logo80 »
mr whippy
Post by mr whippy »
I love my AT 4050
Soundgoo
Post by Soundgoo »
can't lose with a U87
Peace,
Soundgoo
draudio2u
Post by draudio2u »
If you are in the 414 range, you need to hear the Neumann's available in the same price range. I found a TLM170 to work very well with vocals. U87 is a good standby but I would probably grab a U89 first. The studio I am at though has M150's and M149's so if you can swing that, you can't get better.
MacBook Pro FULL, 896HD, 828mkii, DP7... Just go to the web site and look at the pretty pictures ; )
grunter
Post by grunter »
All the mics you've mentioned are "good" vocal mics. You'll find that mic selection is a fairly subjective process. Your best bet is to try to audition the ones you are interested in. I've heard of some people going to a professional recording studio & doing quick auditions on several different mics. Going to a music retailer might be another option although many do not carry some of the high end mics. Unfortunately, a lot of variables come into play when auditioning mics such as room acoustics, mic technique, vocal chain (preamp, eq, compression),etc. Some questions to consider are: what mic preamp will you be using, male vs. female vox, what is the vocal range, what musical genre, are you wanting a "colored" vs. a "clean" sound, a "warm" sound, etc. A good place to start is to go to sites dedicated to recording. One good site I use is: http://www.3daudioinc.com/cgi-bin/ultimatebb.cgi. Good luck!
wonder
Post by wonder »
theres a whole new world when you jump up to the SOUNDELUX ELAM251, or the Telefunken 251, U47, or any other comparable vintage tube mic.
Dual Quad-Core 2.8 GHz Mac Pro 3,1 • Yosemite • 24 GB RAM • MOTU 2408mk3 (x's 2) • DP 10.xx • Finale 25 • Logic • PT 12 • +outboard gear
m2
Post by m2 »
I dig many of the mics mentioned above. My current fav that I just got is a Neumann M149 tube mic. It was too good a deal to pass on. Amazing throughout the range.
Don't forget the mic pre and compressor in the equation. Makes a major difference with any mic setup. I totally dog the Manley Variable Mu comp for cutting vocals as well as the 1176.
Dual 2G-G5/2G ram/Digidesign HD2 Accel/Sony DMX R-100/MeyerHD-1&NS-10s - Hafler Ars Nova/DP5.12/PT7.3.1/2.0+TByte/GigaS3
wonder
Post by wonder »
good call.
do you use the 1176 exclusively or run a through a preamp THEN the 1176?
m2
Post by m2 »
posted June 16, 2005 07:20 PM
good call.
Mic>Micpre>Manley or 1176> recorder [PT; whatever].
The 1176 on mix down is really great. In a rock senario even a plug version of the 1176 - UAD or just the Bomb Factory version-is cool. Clean up the vocal, do whatever pitch correction you want, normalize, compress, split out the breaths and go!
wonder
Post by wonder »
i used an 1176 after a NEVE pre last week. Ever find the inputs of the 1176 are REALLY hot and sensitive?
m2
Post by m2 »
posted June 14, 2005 06:07 PM
I have an AEA R84 as well. Very cool but DEFINATLEY a different flavor. It can be very dark. Get ready to grab some EQ with some cool results. You have to dial in the top but you get tis really neat 'sheen' out of it when you do. Look at a Brent Avril Mic pre for it as well. They make a BAE 312A that has an impedance level that's perfect for it. See: http://www.brentaverill.com/312a/. I'm jonesin' for one bad.
m2
Post by m2 »
posted June 17, 2005 10:00 AM
Not really. Watch the O/P of the pre. We are using a pre for all the gain you get out of it. As you squirt it into the compressor you have to check out your levels . Are all your +4/-10 as well as impedance issues cool?
The 1176 has been around for a long time. it shouldn't be fussy with levels too much. It's the bomb for electric bass of course!
bufdaddy
Post by bufdaddy »
i use a studio projects C-1. i think it is a great budget mic.
wonder
Post by wonder »
ok...i've got to confess....I'm a musician/producer...NOT an engineer. So excuse my retardedness (i realize thats not even a real word).
So ... is it possible to JUST use an 1176 without a PREAMP before it? once again, dont laugh.... :p
i dont own one, i rent them from local audiophile
