I know there was reference to this in the other DP7.11 thread, but I hoped there might be a Console expert lurking here somewhere.
I've been having slow save issues, up to 30 seconds in length. I do have several VEPro instances open, and Omnisphere and Kontakt, and I initially assumed that was the issue. Maybe it still is, but when I ran Console during the save it showed:
29/04/2010 15:07:49 [0x0-0x39039].com.motu.DigitalPerformer[2437] Digital Performer(2437,0xa0aa34e0) malloc: *** error for object 0x810ae020: pointer being freed was not allocated
29/04/2010 15:07:49 [0x0-0x39039].com.motu.DigitalPerformer[2437] *** set a breakpoint in malloc_error_break to debug
These two lines repeat over the 30 seconds before eventually the save completes.
I've tossed prefs, and also just completed an uninstall/re-install of DP from 7.01 back up to 7.11.
Any ideas as to what the issue Console is seeing is?
Andrew
DP7.11 Slow Save issues
DP7.22, MacPro 2.26ghz Quad Xeon, 32GB RAM, OS10.6.6, ViennaInstr/VEPro (crrnt), Waves NPP, PSP (various), Ozone4, Kontakt3 (crrnt), SymphChoirs, Omnisphere/Trillian/Stylus RMX (all current), TruePiano, 2408mk1, 828mk1, Yamaha 01V96
Re: DP7.11 Slow Save issues
not a console expert, but the fellow who posted about slow saves. In my case every 'save' takes up to 10 seconds. I just got off the phone with MOTU tech support on another issue and asked about the slow-save thing. He said 7.1.1 is "more stable and with that stability comes longer opening times and saving times." You seem to have a specific problem from the looks of your report. Give them a call? I hope there is a local number for you!
John
John
MBP 2.66 / DP7.22 / OS X10.9.4 + UltraLiteMkIII
John,
sorry I didn't reference you by name. Thanks for the update on your situation
I believe the initial slow thread your referring to is mine. Do you think the slow merge is also related to the "7.11 increased stability:" statement from the MOTU Tech? I can live with it but when I have a client looking and waiting over a minute for a merge and saying "did we lose the tracks" it gets a bit unnerving. Also I sure wish there was a Merge Progress meter, might be a little more assuring if you could see the write.
MacPro 8 Core 32 GB, MacPro Quad Core 2.66, 8 GB, 2xPCIe424, 2-96Khz 24io's 4-1224's MacBookPro Dual 2.66 i7 2-828 MK2. Allen & Heath GS-3000 32/8 console, eight tons of outboard gear etc. etc.
I appreciate your help.
