Multiple times.MIDI Life Crisis wrote:Also, have you trashed the DP plist?
Tracks Overview strangeness - RESOLVED
Re: Tracks Overview strangeness
DP 8.07 64 bit, OS 10.10.5, Mac Pro 5,1 12-core 3.33ghz, 16GB ram, lots 'o plugs and VIs
Is this in all projects? New? Previous projects?
All projects new and old.MIDI Life Crisis wrote:Is this in all projects? New? Previous projects?
Good thought. Found several sets of duplicate fonts. Removed but no improvement in 7.11Grigri wrote:Hello.
Maybe you could have a look in the fontbook app if there is a conflict with your fonts?
David
DP 7.1 is still fine.
Thanks very much to everyone for their suggestions, this is a strange one.
Strange, I'm having the problem on my imac. I also upgraded my MacBook pro to 7.11 at the same time and it's not happening on the laptop…yet. It didn't happen immediately on the imac. It's not going to be simple I fear.
imac 2.4 Core2Duo 4G RAM, MBP 2.26 Core2Duo 8G RAM/ OS 10.6.8
MOTU 828mk2, microlite
DP7.24, Reason6.5.3, B4II, Ethno, RMX
Sadly not fixed in 7.12
And sadly you're among a very small group of users apparently that is having this problem.mikeka wrote:Sadly not fixed in 7.12
Just so happens that I'm one of that small group. If you have that problem, you'll notice it's not confined to the TO window. Any window with columns is affected. The good news it that it's fixable.James Steele wrote: And sadly you're among a very small group of users apparently that is having this problem.
It's not a DP bug. If the computer is in this condition, you'll see the same problem in DP6 as well as all versions of DP7.
The problem is a font problem. It happened to me because I migrated from an old computer to a new one. During the migration, something gets corrupted in the User Directory fonts. That's why if you switch to a different user account, the problem goes away.
I haven't found any utility that could fix the problem. I had to fix it manually. This is how I fixed it on my system:
Go to User Directory>Library
You'll see a Fonts folder and a Font Collections folder. Create two new empty folders on the desktop. Move the contents of the Fonts and Font Collections folder to these new folders. Log out of the User account. Log back in. Launch DP. Quit DP. Put the contents of the Fonts folders back where they started. Log out. Log back in. Launch DP.
That fixed it for me. How about you?
Dave
Wow! Great info!! Thanks Dave!magicd wrote:I haven't found any utility that could fix the problem. I had to fix it manually. This is how I fixed it on my system:
Re: Tracks Overview strangeness FIXED!!
Dave thank you so much. The fix worked for me. FYI, if this helps at all, on my system all DP 6 versions as well as 7-7.1 were fine. My problem started with 7.11. I've been on the same Mac Pro for a couple of years now so the font corruption must've happened with an OS update done sometime ago.
HOORAY!!! The Magic Man comes through again!!mikeka wrote:Dave thank you so much. The fix worked for me. FYI, if this helps at all, on my system all DP 6 versions as well as 7-7.1 were fine. My problem started with 7.11. I've been on the same Mac Pro for a couple of years now so the font corruption must've happened with an OS update done sometime ago.
Re: Tracks Overview strangeness - RESOLVED
I will try that...I had the same problem on my other Macbook 1.1. I didn't have that problem with the TO on my original setup on my Macbook Pro...I guess I wasn't the only one...
That fixed it. All Hail Magic Dave.
thanks everyone for your help.
Swapped internal drives (causing this anomaly) and upgraded to DP7.2 over three weeks ago and found your explanation and fix (going into a session tomorrow). Just wanted to say BIG thanks for solving and posting.
