Please excuse the repost... Can't delete?
North Coast Sound System
Post by North Coast Sound System »
YES I'm aware of how to adjust the project tempo.
(See chapter 49, pg. 623-630.)
Last edited by North Coast Sound System on Wed Apr 07, 2010 11:55 pm, edited 2 times in total.
Schweats
Re: Change Project Tempo w/o Affecting MIDI Performances?
Post by Schweats »
Yes , however, please explain your concerns that would lead you to ask such a question ?
Tempo change is facilitated in the Conductor track - read up on it
HTH - Schweats
Schweats
MacPro 2.8/OS 10.10.1/6g ram/Powerbook G4/1g ram/10.4.11/828 mk3 hybrid/MTP AV usb/DP 7.23/Stylus RMX/Omnisphere/Trilian/Mach Five v2/RealGuitar/Korg Oasys/UAD2-Quad card & various plugs/Novation Zero SL mk2 controller/Akai MPK61
You can change a project tempo from several places depending on the situation. That's not my question. If you've recorded MIDI information at say, 156bpm but then realize that actually the tempo should be 75bpm (half)
When you change the tempo the MIDI performance expands or contracts to keep in place with the tempo change. As I stated I want to change the tempo WITHOUT affecting the MIDI performance. I.E. the playing stays the same but the tempo changes. Hopefully others got that from the title? :-(
Lock the track.
BTW, one post is sufficient and efficient... :roll:
cuttime wrote:Dude, chill.
Also very good advice... LOL!
Not used to your format here. Please excuse the double post.
I was afraid I was going to get a bunch of un helpful references to read about tempo change in the manual....
Thanks again.
