zed wrote:cbergm7210 wrote:zed, I use AHP all the time with DP / Bidule projects. Is there something different than the usual process of hijacking the audio from DP when Bidule is involved?
Well... to tell you the truth... I didn't set it up with an Aux in DP because I didn't have to. Bidule output components just showed up automatically in my Tracks overview and they worked just fine without setting up an Aux.
But I realize that this means (I believe) that I am hearing the signal from my 2408 outputs, and it is not actually being passed through DP, which is why Audio Hijack is not capturing the signal, and why the behavior is the same as the external MIDI modules which I have set up this way.
But when I tried to set up an Aux track to get the sound routed directly through DP I could not find a way to get any signal into the Aux track. I tried all the Plogue Bidule Device outputs and none of them carried any signal, even though I could hear Bidule VIs playing as DP was playing. So there must be something I have to do in my actual Bidule template in order to get the signal routed into one of those Plogue Bidule Device outputs.
Still a bit of head scratching to do, but I'm glad to hear from you guys that it is possible to set this up so that it will work conveniently with Audio Hijack, etc.
Zed. I don't know if this will help or not, but this is what I did--
1. Open Bidule. From its Preferences change the Virtual MIDI Ports from 4 to 16 or 32.
2. Close Bidule and then launch it and close it again.
3. In DP
a.) Go into Bundles > Instruments and change the name of Bidule's bundles so they're not as long. If they're not showing up in the vertical column just add them.
b.) Add an Aux track in DP with Bidule 1-2 as the input (this will make Bidule go into Rewire mode when you launch it).
c.) Output the Aux to whichever outputs you usually use for monitoring. (I leave the routing up to you).
4. Launch Bidule.
5. From Bidule's Pallette:
a.) MIDI Devices > Input. Drag the Bidule-1 input into the work area. (You can also ctrl click in the grey area and select from the menu.)
b.) Open the AU Music Devices folder. Drag whichever library or player you want onto the work area.
c.) Connect the MIDI device and Music device with a cable.
6. Double click on the Music device module and load in an instrument.
7. Right-click on the MIDI device and and select Rename so you can name it something useful (this will show up in DP). Do the same for the Music device.
8. Connect the first two outputs of the Music Device to the first two inputs of the Bidule Rewire device.
9. Go back to DP.
10. Add a MIDI track and output it to the Bidule Aux. Input from your MIDI keyboard.
I think that's it.
c-ya,
Dan Worley
