Hi
I am sure this has been addressed somewhere in this forum, but, I haven't the exact answer first. Here is my issue;
I am trying to do a tap tempo function (trying to record a new click track to an existing audio recording.) I have tried to follow the guidelines in the MOTU manual and it doesn't cooperate.
So, as work around, I created a MIDI track, loaded a drum kit VI and recorded a hi hat click along with the audio (its solid to the existing audio piece.) Now the question is; how do I convert THIS new MIDI click track into my conductor track to have this as my NEW click/tempo track?
Shawn
Click Track Issue
Click Track Issue
Mac Pro Quad Core, 2.93GHz, OSX Snow Leopard 10.6.2, Digital Performer 7.02, Gigastudios, MTP-AVs, MOTU 208mk3, Kirk Hunter, Jeff Sigurdson Guitars, Universal Audio, Spectrasonics, Sonic Implants, Bogner, Deering Banjos, G-String Ukeleles, Ultra Focus, Mach 5, VSL, Native Instruments, Rode Mics, Sibelius 5, Waves, Line 6, Tom Anderson Guitarworks, Wave Arts, Universal Audio, Mackie HR 824's
Re: Click Track Issue
There is no way to convert a MIDI track to a conductor track that I am aware of. You might align beats to the MIDI track and then delete the or mute the MIDI track.
Not sure why you are having click track problems in the first place, however. I rarely use click tracks but I can certainly check it out for you on my system. Are you simply trying to follow the metronome? Or are you trying to adjust beats after the recording? You mention tap tempo so I assume the latter. I know there was a tap tempo issue but i thought it was fixed in DP 6. Maybe it's back?
