ok, some fantastic news and also a need to do update as well for the hardware.
tonight i spent a few hours fine tuning the controller, so much so that everything worked as i needed it too. i mapped a load of controls to the software, saved the kit and samples down. i then closed bpm, reloaded it and all my controller settings were saved for that kit and mapping.
i then applied a sample to a pad and assigend the solo, and mute to buttons on the controller in a different group in the banks, i also did the same with the volume and balance for a few pads. using this method i was able to control each contol in the software easily.
plans: prehaps a little expander unit for the balance and volume, solo ,mute for each pad, i have room to do the buttons on the tp panel but not for the faders, i cannot get them small enough, however i have seen some faders that if i change the pads and the fsr strip underneath it would allow me to position them as per the software. this is omething i am now going to look into over the next few weeks as soon as this is finished. the secend version of the controller is going to be a little better than this one i think.
i need edit the pads for note on/off as they are only sending on at the moment. but thats done in the editor and takes a few seconds.
i will do another vimeo tomorrow, showing the filters going over samples in realtime with the controller and using the faders etc.
all in all a very productive day today and the response from the software with the controller is instant!!
can you tell im a little excited
