It sounds to me like you're trying to print the effect to a piece of audio rather than placing the device as an insert in the mixing board.lamboguy wrote: But now I'm adding (or trying to add) the MasterWorks Limiter and running into all sorts of problems. Sometimes "Preview" works, but mostly it's grayed out.
I don't see much in the manual as far as how to hook the danged thing up with the master slider, which is what they suggest. Is that an automatic thing?
I'm either getting very erratic behavior from it, or nothing at all...occasionally it is definitely doing something, but typically "craps out" after a bit. I'm not sure if that's a function of the preview or whether I'm doing something wrong...or:
Is MWL a memory hog? I'm wondering if I'm just hitting a ceiling as far as memory goes. But also, I can't seem to get the darned thing to work.
Am I missing anything other than opening it? It doesn't need to be actually installed or anything, does it?
Could that be the case?
This is not the way to work with the MW Limiter.
Check out "inserts" in the manual.
What you described is basically what freezing a track does. It sets up the bussing automatically and it should prevent the VI form playing in your track, to prevent doubling.lamboguy wrote: Now, as for freezing the track, it sounds like something I need to look into. No, I haven't used that, just went ahead and played the track as I'm recording to a stereo soundbite track. (VI's to bus in and soundbite track recording from that bus) -- then bounce to disk, and works great.
It's just a convenience really, speeds up the workflow and saves resources.
