Mic Pre S/PDIF Work with Mk1 2408?
tubanick
Post by tubanick »
Hi all.
Been a long time!
Resurrected my old G3/os9, AudioDesk 1, 2408 Mk1.
Current goal is to improve the signal path.
(Besides. I really should return my friends ART MP ;) )
My understanding is that the Mk1 signal path from S/PDIF to HD is 24 bit.
The 2408 is old and I don't know if there's been any changes
in S/PDIF (specs? format?) so....
Anyone know if the S/PDIF on these types of preamps:
http://www.artproaudio.com/products.asp ... t=9&id=145" onclick="window.open(this.href);return false;
http://www.artproaudio.com/products.asp ... at=9&id=97" onclick="window.open(this.href);return false;
will work with the Mk1 2408?
Neil.
Radiogal
Re: Mic Pre S/PDIF Work with Mk1 2408?
Post by Radiogal »
I don´t see why there would be any problem with what you want to do.
I have used the 2408 MK1 , 2 and 3 in the same setup with SP/DIF gear connected to them. I´d give it a shot without hesitation.
mandobilly64
Post by mandobilly64 »
I used to use the DPS II with my Motu 828 MkII and the only thing I can say about using the SPDIF input on the MOTU was that I had to set up the clock to sync to the SPDIF and use the ART as the Master clock. It was the only way it worked right. My ART unit did give me some problems, one sides LED doesn't work and the Digital outs ended up being a little scratchy and one side cut in and out. I'm not using it right now, but it does have some decent mic presets for different instruments.
Peace,
Billy
tubanick
Post by tubanick »
Thanks Radiogal and Billy.
Seems it should work with my Mk1 2408/324.
But... even w/Cuemix, 324 latency seems higher than hoped and can't trust that pops/clicks won't crop up again, computer/OS is old (wah wah wah) so....
Seems I need to upgrade.
I wonder if fastest G4/early G5 + Reaper + 10.4 would work with my Mk1? I see OSX 324 drivers on MOTU site.
Help appreciated,
Neil.
If you are really using CueMix to monitor, you will not get any perceivable latency. CueMix is a hardware digital mixer built in the 324. Switching computers and/or software will not impact the nominal processing delay CueMix operates with.
rodger1811
Post by rodger1811 »
HCMarkus wrote:If you are really using CueMix to monitor, you will not get any perceivable latency. CueMix is a hardware digital mixer built in the 324. Switching computers and/or software will not impact the nominal processing delay CueMix operates with.
I'm VERY late on this post but I want to point out that the PCI-324 card didn't have Cuemix DSP. The onboard DSP Cuemix came along with the PCI-424 card.
Mid 2012 Mac Pro 12 Core 2.4GHz, 24G RAM, OSX 10.8.2, DP 8.01
4x2 TB Hard Drives
APOGEE Symphony
MOTU 2408 mk3
MOTU HD192/Black Lion Modified
MOTU 24I/Ox2
MOTU MIDI Timepiece
Universal Audio UAD-2 Quad x 2
Universal Audio (Entire Plugin Library)
Waves Mercury+ Studio Classics
Tons of other goodies; to many to mention here
