http://www.motu.com/video-products/hdx-sdi/
BradLyons wrote:This is EXACTLY what I need....... thank you MOTU, THANK YOU THANK YOU THANK YOU
The HDX-SDI is not an audio interface either. It's audio inputs and outputs are not exposed to Core Audio like the V4HD's inputs and outputs are. Currently, the HDX-SDI's audio I/O only works with Final Cut Pro.BradLyons wrote:Those boxes are NOT audio interfaces, however...and that's the key here.
And Premiere.1nput0utput wrote:The HDX-SDI is not an audio interface either. It's audio inputs and outputs are not exposed to Core Audio like the V4HD's inputs and outputs are. Currently, the HDX-SDI's audio I/O only works with Final Cut Pro.BradLyons wrote:Those boxes are NOT audio interfaces, however...and that's the key here.
Right...but that's how it will be used by myself and others that use it. For example I'll be recording via a Sennheiser EW152 headset wireless microphone through whatever micpre/compressor/eq chain I pick along with a stereo mix from ProToolsHD along with a Shotgun microphone going through a pre.....that's (4) channels of discreet audio I'll be recording along with the video, simultaneously into FinalCut----thus why THIS box fits a huge ticket and makes perfect sense.1nput0utput wrote:The HDX-SDI is not an audio interface either. It's audio inputs and outputs are not exposed to Core Audio like the V4HD's inputs and outputs are. Currently, the HDX-SDI's audio I/O only works with Final Cut Pro.BradLyons wrote:Those boxes are NOT audio interfaces, however...and that's the key here.
And see, that's what I don't understand about what everyone's saying about the HDX... I asked Dave on the Creative Cow forums if DP would recognize the HDX... He responded:1nput0utput wrote:The HDX-SDI is not an audio interface either. It's audio inputs and outputs are not exposed to Core Audio like the V4HD's inputs and outputs are. Currently, the HDX-SDI's audio I/O only works with Final Cut Pro.BradLyons wrote:Those boxes are NOT audio interfaces, however...and that's the key here.
What bit depth and sample rates does it operate in DP? What about video?Terra303 wrote: I had already ordered the HDX, so I tried it anyway in DP
So far the only combination I've tried is the one I normally use (24bit/44.1k)...Jim wrote:What bit depth and sample rates does it operate in DP? What about video?Terra303 wrote: I had already ordered the HDX, so I tried it anyway in DP
