Sorry for that. I should have made the window smaller. It fits nicely on my 1680x1050 monitor though.mhschmieder wrote: Thirdly, it was difficult to work with the project because Apple insists on only providing window resizing hooks in the lower right corner, and that was completely inaccessible to me as you can't drag a window above the Apple menu bar. This is a HUGE window in this project.
Not quite. In the oboe part in the second phrase the fifth note sounds much quieter than the rest and with a click. The first phrase is given for the contrast. In the flute II part quite a few transitions have noticeable clicks.Finally, I am assuming by glitches, that you are referring to the lack of smoothness when transitioning between notes that are large intervals apart (close to an octave, in a couple of cases). I have experienced this as well, and due to expediency have usually switched to another articulation in those cases.
VSL states that it covers transitions up to an octave apart in its legato patches. In the project the notes under suspicion rarely exceed a fifth as far as I remember.
I found in some cases that note overlaps sound worse with VSL, especially on legato patches. The algorithm seems to track the interval between notes and engages automatically when it is below some threshold (50ms?). So it makes no sense to overlap them and you have to put the notes significantly apart from each other to avoid triggering the legato.I tried different note lengths, both with gaps and with overlaps (you used neither, and set the notes to begin when the previous note ends, which with most libraries does not guarantee legato but probably doesn't matter so much with Vienna due to the dedicated Legato setups).
Obviously I cannot change the tempo of the piece but it gives me the idea that maybe legato patches are not meant to be used at slow tempi. I could use a sustain patch but it brings another problem with the VSL oboe: the sustain patch has different timbre and different number of layers so it is tricky to use it along with the legato patch.If I sped up the Conductor track, the glitches went away. I didn't try a lot of numbers, but even at 150% of your very slow tempi, the glitches disappeared. They also became less noticeable if I lowered the Attack velocity of the high note in the large intervals (something a real player would tend to do anyway).
By MIDI specification Note Off velocity specify the release time which is often irrelevant to the the instrument played. I also noticed that legato patch sounds the best if the same velocity is used apparently due to the fact that the layer crossfade stays constant. BTW VSL recommends to automate layer crossfades instead of using velocity.So I initially thought maybe the MIDI was non-ideal, as you used precisely the same note lengths and note velocities for every note. I also tried different Note Off velocities vs. the zeroed values in your file. I couldn't discern a difference, so probably VSL doesn't make use of that increasingly irrelevant MIDI CC.
So it seems like it makes little sense to upgrade to the full woodwinds library then. VSL is obviously having its peculiarities that one has to live with.BTW your French Oboe from SE corresponds to Oboe II in the regular edition. I had to figure that out by ear due to my computer's restrictions on launching PDF's or browsers while running DP. The Oboe II has a much sweeter tone to my ears than the Oboe I, so it's a shame that throwing your nice super-slow melodic line at it isn't a slam dunk.
Again it confirms that perhaps the legato patches are not for slow tempi.Note that the Matrix patch that I used was the Legato-Interval-Speed patch. But it behaved almost the same as the single patch for Legato, which isn't surprising due to the slow tempi of the material.
Thanks again for your time and effort, it was a great help! It clearly looks like the difference between SE and full VSL is only in number of articulations and not in the quality of the material and software.
Thank you and Happy New Year!
