Digital Clicks From New 24I/O
The Ronin
Post by The Ronin »
I am using a brand new 24 I/O. I have outputs 1-2 enabled for playback, but I am seeing sporadic output on #3 (NOT ENABLED FOR OUTPUT). When I see the output on ch 3, that is when I hear the clicks in my monitors. Any help or ideas would be greatly appreciated...
The Ronin
G4 867 Ti Power Book (Tiger)
Magma PCI chassis (PCMCIA)
MOTU 24I/O
Logic Pro 7.1
Live 4.1.1
Hardware/Software
sexyvocalist
Re: Digital Clicks From New 24I/O
Post by sexyvocalist »
I may be way off here... But it sounds like maybe your PCI 424 console may not be setup just right... I still have the PCI 324 card, with 2 1224's, and I always set everything "From Computer" that way I have more control over everything in Sonar... What type of setup are you using?
Will
AMD Sempron 2200+
GF MX4000 64 MB DDR Graphics Card
640 MB DDR333
200 GB HDD
80 GB HDD
2 MOTU 1224's
Sonar 3 Producer's Edition
Sonar 4.2 Producer's Edition
Tons of DX, VST, & RTAS plugins
sexyvocalist
Does the new 24 I/O come with the cuemix and 424 console? Like I said, I may be WAY OFF here...
Will
AMD Sempron 2200+
640 MB DDR333
200 GB HDD
80 GB HDD
2 MOTU 1224's
The Ronin
Post by The Ronin »
Yeah, it comes with both apps. I couldn't see where in "audiodesk" I could fix my problem and everything in the 424-PCI controller is set the way it should be so I am still at a loss. Phone support from MOTU is a busy signal so no help there as of yet.
Aaron
MOTU 24I/O
Logic Pro 7.1
Live 4.1.1
Hardware/Software
XHipHop
Post by XHipHop »
I have the same exact problem with two Motu HD192's. I switched wires, switched units, changed what audiowire port they were attached to...and i always get that channel 3 click.
I'm using them with tiger so maybe that's the problem. Anyone else?!?!?!
The Ronin
Post by The Ronin »
I am also using Tiger, not sure if this is a bug with tiger or not???
Still no help from MOTU
MOTU 24I/O
Logic Pro 7.1
Live 4.1.1
Hardware/Software
XHipHop
Post by XHipHop »
it has to be with the tiger driver! i'm going to call them tommorrow all day and hopefully i'll get through.
I need to get rid of those pops.
XHipHop
Post by XHipHop »
couldn't get through! :o
Monday, i guess...
What computer do you have by the way? I'm using a 867mhz G4 quicksilver power mac.
sscp
Post by sscp »
Its not tiger Iam still on panther and have the same problem with a HD192 at one point i changed the cable slot and it went away for a while but now its back
XHipHop
Post by XHipHop »
That's really strange. So i guess it is NOT a software issue.
I wonder if we have a bad batch of 424 cards or something?!?!
I hope someone at Motu has an answer.
The Ronin
Post by The Ronin »
Sorry to hear that I am not the only one with this problem, but it does make me feel better that it is not only me. Thanks to all of you for your input thus far and hopefully MOTU has an answer for us all. Please share any developments and I will make sure to do the same...
MOTU 24I/O
Logic Pro 7.1
Live 4.1.1
Hardware/Software
beardedlurker
Post by beardedlurker »
i am a little late to the party, but still...
i have been having the same problem, using (2) hd192's on a dual 1.8ghz g5 w/ 1.5 gig of ram. i've tried switching the pci card to all 3 available slots, tried switching the cables to different ports, everything i can think of. i notice that the pci bargraph meter in my cuemix console is always peaked out in the red, and i only get the clicking on the second hd192 (outputs 13-24). i never had this problem when i was using the same setup on my older single 1.8ghz g5, even at 24/96k. and of course i've gotten no reply from motu tech support. if anyone finds a solution, please post it. good luck!
-mark
kiddkubi
Post by kiddkubi »
hi all, im having the same issues here with pc (xp) i spoke with motu and the guy i talked to said to try switching pc1 slots , changing out the fire wire cable , and (your gonna love this one) ;)
<small>[ June 30, 2005, 08:31 AM: Message edited by: thetrackshack ]</small>
kiddkubi
Post by kiddkubi »
hi guys , i talked to motu and they are going to bench test the 24io and send me a new one if it is indeed broken . thanx for all your help and thoughts.
p.s. is there anyone here that i can call that would be interested in talking about there specific set up and latency settings ? if so please email me , or post there telephone number's . my studio phone # is (609) 965 4553. my name is Joe DeFalco i live in new jersey and im at the studio from 5:30 till 11:30 usually every night . thanx again for all your help
www.thetrackshack.org
Rpro
Post by Rpro »
Mute any and all channels you don't need in the cue mix setup. Choose outputs on the right then mute all channels that are not needed.
