Buffer size hidden is vey annoying
Wouldn't it be nice to have the buffer size displayed right next to the Clocksource, Sample rate etc, etc.? A dropdown menu just the way you can select your clocksource, samplerate etc would be soooo convenient. I hate opening the Configure Hardware setup only to notice that the buffer size is already set to 1024 and then hitting the cancel button and having to wait for the VIs to reload. I don't understand why MOTU has not dealt with this since I have already read someone posting this before.
Alex
Mexico City
Mexico City
Re: Buffer size hidden is vey annoying
It sure is.Buffer size hidden is very annoying
Yes, yes and yes. i thought this just the other day.wurliuchi wrote:It sure is.Buffer size hidden is very annoying
Agreed +1!
Computer/s: OSX 10.8.3
2 x 2.66 GHz Mac Pro Quad-Core Intel Xeon w/ 16GB RAM,
DAW:DP8.05
Hardware: Apogee Duet
VI's/Plug-ins:
Kontakt 5.1, EW PLAY Libraries and a
million others.
DAW:DP8.05
VI's/Plug-ins:
million others.
+1
iMac Intel Core i5 3.2ghz - 16gb RAM - OSX 10.10.5 - DP 9.01 - Mach Five 3.2.1 - Ethno Instrument 2.0.3 - Kontakt 5.4.3 - 4pre - 828 original - micro express
Yeah; hit 'Cancel' but the whole audio system, VI's and all still has to reload.
That's a real funny joke, I'll say!
It would be nice for Buffer to be right there.
I accidentally solved an Automatic Delay Compensation problem yesterday when I switched my buffer from 256 to 128, then back to 256. I didn't realize this would give the ADC a kickstart. I was able to continue my Parallel Compression experiments with far less hassle.
Now I want the Buffer indicator visible at all times.
MacBookPro 1.83GHz Core Duo, 2G RAM.
OSX 10.6.8
DP 5.13
MOTU 828
Tascam cassette 4trk
OSX 10.6.8
DP 5.13
MOTU 828
Keyword: annoying
Sorting to the "Gripes" section where it belongs.
<sigh>
I can't resist - this feature is more hidden in Logic than DP
and everything still has to load in L as well. So there
- kassonica
In unison from down under......MIDI Life Crisis wrote:<sigh>
+1.
I will add that I am finding 256 is actually useable for perfomance in DP6.02, and my Quad G5 handles pretty big projects at that buffer size, so this isn't quite the issue it used to be. Still, why not give us a little window MOTU? Pretty Please?
- daniel.sneed
Yes, one small window would be perfect !
Please, Motu, lend an ear about this one !
dAn Shakin' all over!
When I track VI's I know that I'm @ 256...
I only switch it when I go to mix so I know what it is already.
Why you'd need to go back and forth is the issue... I guess I'm just set in my ways of habit.
Track @ low settings... mix @ high. Unless your going back and retracking I can't see changing them more than once per session but thats me.
